Which software is best for creating a virtual COM port?
I’m working on a project that requires a virtual COM port to connect devices that don’t have a physical serial port. I’ve tried searching online, but there are so many software options and I’m not sure which one offers good compatibility and is easy to use. Could someone recommend reliable software for creating virtual COM ports? Any advice from people who have faced this would be really helpful.
Virtual Serial Port Tools: My Journey Into the Rabbit Hole
So, I’ve spent way too long mucking around with emulated hardware on Windows. You know when you’re trying to connect old-school gear and your laptop is like, “Serial port? Never heard of her.” Yeah, that’s me, every project. In my latest face-off with legacy stuff, I stumbled across this tool: Virtual Serial Port Driver. Can confirm, it’s not snake oil.
Set-Up: Fast, but Not Magic
You basically pick a couple menu options, smash the “create” button, and bam—a new serial port is born. Not kidding, I got it up and running before my coffee cooled off. No arcane command lines. No registry voodoo. The ports show up in Windows and act just like the grumpy old COM1/COM2 dinosaurs, but without the random “Access Denied” meltdowns.
Why Even Bother?
Imagine running two programs that both want to listen to one serial port, like two dogs fighting over a bone. With this, you can split the feed and share it out, so everything gets a bite. I threw it into the ring with some ancient CNC control software and serial logging tools (yes, I’m that guy), and it didn’t even flinch.
Downsides? Sure.
It’s not like it turns your laptop into a teleporting spaceship. Sometimes you gotta mess with driver permissions, and the first time Windows chimes in with “Installing drivers,” my heart skips a beat. But so far, no blue screens.
Hot Take
If you’re cobbling together serial gadgets and need to fake real ports, this tool saves you from fiddling with crusty adapters. Bonus: splitting signals means you can debug and run the app at the same time. Wish Windows would just build this in, but until then, here’s your flashlight for the tunnel.
Honestly, when it comes to emulating a serial port so your ancient hardware or serial-hungry apps will stop crying about “COM ports not found,” it’s a bit of a jungle out there. @mikeappsreviewer swears by Virtual Serial Port Driver—and I have to admit, they’re not totally off-base. It’s robust, straightforward, and lets you instantly set up virtual COM ports effortlessly so your software thinks it’s the real deal. The loopback features and splitting capability are also huge if you’re juggling debugger tools and service apps.
BUT, I wouldn’t be me if I just waved pom-poms and called it a day. For starters: free options—com0com comes to mind, although it’s a little more “install this driver and pray” than plug-and-play. It’s open source, but the UI is, let’s say, “minimalist.” You’ll need to wrestle with config settings. It’s powerful, yeah, but might make you want to yeet your laptop out the window.
Also worth considering: Eltima’s Virtual Serial Port Emulator (different from the driver) is in the same league, especially if you need advanced port management or are simulating fancy, multi-port gear.
The Windows “built-in” support: it’s non-existent. Don’t even bother unless you’re into self-flagellation via registry editing.
Quick Pros of Virtual Serial Port Driver:
  • Ridiculously fast to get going
  • Good for splitting/mirroring ports
  • Reliable enough for most dev/test environments
Drawbacks:
  • Paid, so if you’re on a ramen budget, ouch
  • Not open source; so tweaking is limited
  • Driver installs can spook your system if you’ve got strict policies
Short answer: If you want to save yourself from hours of debugging driver hell, Virtual Serial Port Driver is worth the investment. If you just need something basic and are cool with a little pain, try com0com. There’s no perfect answer but for most Windows users with actual stuff to build, VSPD is stupidly efficient.
You’d think that with how many devices still need a COM port in 2024, Windows would just toss in a built-in virtual COM creator, right? But nah, Microsoft basically left us for dead—so cue the endless parade of “serial port emulators.” I read through @mikeappsreviewer’s praise for Virtual Serial Port Driver and @yozora’s rabbit-hole rant, and yeah, both bring up solid points. VSPD is slick—feels pro, minimizes drama, you get some actual GUI (rare in this niche), and can split/share ports easier than most. It’s honestly the big kid on the playground, if you don’t mind paying for convenience.
But let’s not ignore the elephant: com0com. It’s free, and while they’re not kidding when they call the UI “minimalist,” it will get you a virtual port if you have the patience (and some spare patience lying around). It’s just rough around the edges, kinda like diy home repairs—sometimes it turns out great, sometimes you wish you never started.
Then you got Eltima’s Serial Port Emulator, which is like VSPD’s cousin that went to finishing school—sleek, pro, expensive. Overkill for most, unless you’re running cyborg-level simulations.
If you just want to set up some ports fast and don’t want your weekend ruined by driver headaches, VSPD is where my money would go (and did, honestly). But I won’t sugarcoat it—the free options demand some sweat equity and mulitple tabs of StackOverflow.
Oh—if you do end up pulling the trigger on VSPD, I found their post-download resources surprisingly useful. The step-by-step is actually human-readable, so worth checking out here: getting started after your Virtual Serial Port Driver download.
tl;dr: Paid = painless-ish. Free = bring a helmet. Either way, welcome to the serial jungle.
Here’s how the virtual COM port scene shakes out, from the trenches: Virtual Serial Port Driver is widely recommended for a reason. The pro list is solid: fast GUI setup, no command line acrobatics, and it actually shows up in Windows Device Manager the way you want—with real multi-port support and signal splitting. I’ve banged on it with apps running in parallel and didn’t see the lag or port lock issues you sometimes hit with open-source options.
Where it trips up: it’s pretty wallet-unfriendly if you’re just dabbling (and the occasional driver grumble during install). Also, not cross-platform—strictly a Windows party. And honestly, the advanced features could be overkill for bread-and-butter projects.
Alternatives like com0com are, let’s be honest, a DIY adventure: it’s open-source, free, does the job, but with a UI that hates you and setup docs that read like a dare. Eltima’s Serial Port Emulator comes super-polished, yet at a price point most hobbyists will scoff at unless they’re running big-time industrial app tests.
If your priority is “click, done, works,” you’ll gravitate toward Virtual Serial Port Driver—I do, especially when time is money. Just know you’re paying for that ease. If you love fiddling or need a zero-cost option, com0com won’t steer you wrong as long as you don’t mind some pain. Either way, as echoed by others, Windows’ refusal to include this natively is wild in 2024.
