What’s the best partition recovery software?
I accidentally deleted a partition on my external hard drive and lost important files. Could someone recommend reliable software for recovering partitions?
Top Data Recovery Tools for Mac & Windows: Free and Paid Solutions
Have you ever accidentally deleted an important file or experienced the horror of a system crash? If so, you’re not alone. Losing critical data can happen to anyone, whether it’s due to human error, formatting mishaps, malware, or hardware failures. Thankfully, today’s data recovery software can salvage your files and bring them back to life. Let’s explore the leading tools available to rescue your data, including their key advantages, limitations, and when to use them.
1. Disk Drill (Mac & Windows)
Why It’s a Winner:
Disk Drill stands out as one of the most powerful and user-friendly recovery tools on the market. From beginners to IT professionals, its comprehensive features make it a versatile choice for a range of data recovery needs.
Strengths:
  • Intuitive Interface: Perfect for first-time users.
  • Multi-Format Recovery: Supports over 400 file formats, including photos, documents, and videos.
  • Additional Tools: Includes helpful features like Recovery Vault for added data protection.
  • Generous Free Trial (Windows): Recovers up to 500MB without charge.
Weaknesses:
  • Mac Limitations on Free Version: Only previews files without recovery.
  • Patience Required: Deep scans can be time-consuming.
  • Pricey Full Version: To unlock its full capabilities, you’ll need a paid license.
Verdict:
With an easy-to-navigate design and robust capabilities, Disk Drill is ideal for individuals and professionals alike.
Learn More: Disk Drill Official Website
Further Reviews: Reddit’s take on Disk Drill
2. EaseUS Data Recovery Wizard (Mac & Windows)
What Sets It Apart:
EaseUS takes the hassle out of recovering files with its incredibly simple three-step process and cutting-edge AI scanning technology.
Strengths:
  • Quick and Easy: Simplified recovery steps make it beginner-friendly.
  • AI Integration: Recovers files using advanced deep-scan algorithms.
  • Free Version Value: Offers up to 2GB file recovery at no cost.
  • Partition Recovery: Can restore RAW file systems and lost partitions.
Weaknesses:
  • Free Version Cap: 2GB may not suffice for substantial losses.
  • Scanning Times: Deep recovery requires patience.
  • Paywall for Full Features: Unlimited file retrieval needs a subscription.
Verdict:
A dependable option for common recovery tasks, with its free version offering significant utility for everyday file restoration.
Read Reviews: EaseUS Review on Reddit
3. Recuva (Windows Only)
Free and Effective:
For Windows users seeking a no-cost solution, Recuva stands tall. It’s lightweight, portable, and focused on simplicity.
Strengths:
  • Completely Free: No limits on file recovery.
  • Snappy Performance: Fast scan and recovery process.
  • Portable Version: Ideal for on-the-go recovery without installation.
Weaknesses:
  • Limited to Windows: No Mac compatibility at all.
  • Bare-Bones Features: Lacks advanced options like deep scans or RAID recovery.
  • Challenged by Severe Damage: Struggles with files on heavily corrupted storage.
Verdict:
If you need a basic and straightforward recovery tool on Windows, Recuva is perfect without costing a dime.
User Feedback: Recuva Review on Reddit
4. Stellar Data Recovery (Mac & Windows)
Feature-Rich and Reliable:
A constant favorite among professionals, Stellar specializes in recovering multimedia files alongside traditional data.
Strengths:
  • Diverse File Recovery: Handles photos, videos, emails, and more.
  • Device Compatibility: Works with hard drives, SD cards, and USB devices.
  • Free Version Capabilities: Provides up to 1GB recovery for no cost.
  • High Success Rate: Exceptional at retrieving corrupted or lost files.
Weaknesses:
  • Free Tier Limits: No more than 1GB without upgrading.
  • Scanning Speed: Deep scans are relatively slow.
  • Costly Premium Features: Advanced repair tools require an investment.
Verdict:
Ideal for those seeking a versatile recovery tool with multimedia repair abilities, particularly for photographers and content creators.
5. TestDisk & PhotoRec (Mac & Windows | Open-Source)
Tech-Lover’s Dream:
For those who enjoy diving into the technical side, this open-source duo is powerful and completely free.
Strengths:
  • Totally Free: No paid versions, ever.
  • Deep Scanning Expertise: Excels at partition recovery and inaccessible drives.
  • Cross-Platform: Compatible with nearly every major OS.
Weaknesses:
  • Steep Learning Curve: Command-line interface may scare off beginners.
  • No Graphical Interface: Lacks the click-and-point convenience we’re used to.
Verdict:
This combo is a lifesaver for advanced users who aren’t afraid to roll up their sleeves.
6. R-Studio (Mac & Windows)
Heavyweight Champion:
R-Studio’s advanced toolkit makes it the go-to for IT professionals tackling large-scale recovery operations.
Strengths:
  • Unmatched Power: Handles RAID recovery and works across countless file systems.
  • Network Capabilities: Ideal for recovering data remotely.
Weaknesses:
  • Hard to Navigate: Designed for experienced tech users, not casuals.
  • No Free Recovery: Paid-only software for major file restoration.
Verdict:
A high-end, specialized tool reserved for tech-savvy folks and professional data recovery needs.
7. Wondershare Recoverit (Mac & Windows)
Perfect for Video Enthusiasts:
Offering specialized features like video repair and extensive format support, Recoverit is unmatched for multimedia recovery.
Strengths:
  • Easy-to-Use Design: Welcoming for all.
  • File Coverage: Restores over 1,000 file types.
  • Unique Features: Tailored tools for video repair and recovery.
Weaknesses:
  • Limitations on Free Tier: Only 500MB available without paying.
  • Scan Speed: Deep dives into corrupted drives could use optimization.
Verdict:
An excellent pick for retrieving video content, appealing to filmmakers and casual users needing reliable recovery software.
8. Ontrack EasyRecovery (Mac & Windows)
Pro-Level Precision:
A trusted name in the recovery industry, Ontrack’s comprehensive features support both professionals and general users.
Strengths:
  • Versatility: Handles RAID recovery and massive drive issues.
  • Generous Free Tier: Restores up to 1GB for free.
  • RAID Support in Top Tiers: Designed for complicated storage solutions.
Weaknesses:
  • File-Size Cap: Free recovery limited to files under 25MB.
  • Costly Tiers: Premium options are not budget-friendly.
Verdict:
A fantastic professional-grade tool when tackling more advanced recovery challenges.
9. Prosoft Data Rescue (Mac & Windows)
Reliable for Deep Recovery:
Well-suited for both casual and expert Mac users, Prosoft’s pay-as-you-go system tailors to unique personal needs.
Strengths:
  • Drive Cloning: Protects data during recovery on failing drives.
  • Mac Expertise: Designed with Apple systems in mind.
Weaknesses:
  • Confusing Payment Model: Charges based on recovery extent.
  • No Lifetime License: Continual use requires repeated purchases.
Verdict:
An especially valuable tool for resolving tough data losses on macOS.
10. MiniTool Power Data Recovery (Windows Only)
Best Value for Beginners:
This tool’s ease of use and low learning curve make it a solid choice for those exploring free Windows solutions.
Strengths:
  • Streamlined Experience: Intuitive process for quick fixes.
  • Free Version: Capable of up to 1GB recovery.
Weaknesses:
  • Limited to Microsoft Systems: No Mac support.
  • Not Intended for Complex Scenarios: Best used for simpler recoveries.
Verdict:
A straightforward, budget-friendly tool for casual Windows users.
Final Recommendations
Select Based on Your Needs:
  • Best for Beginners: Disk Drill, EaseUS Data Recovery Wizard, Wondershare Recoverit.
  • Best Free Option: Recuva (Windows), TestDisk & PhotoRec (Mac & Windows).
  • Best for Experts: Disk Drill, R-Studio, Ontrack EasyRecovery, Prosoft Data Rescue.
  • Best for Multimedia Recovery: Wondershare Recoverit, Stellar Data Recovery.
When facing minimal file loss, start with free tools like Recuva or EaseUS. For deeper or more critical recoveries, investing in paid solutions such as Disk Drill or R-Studio can save the day.
!DUDE, you deleted an entire partition? That’s like losing a piece of your soul in the digital abyss! Alright, let’s untangle this mess.
If you’re looking for the best shot at bringing that partition back, Disk Drill is honestly a solid pick. Yeah, I know @mikeappsreviewer already hyped it up, but for partition recovery specifically? It’s not just hype—it genuinely slaps. It’s got this handy partition search feature that scans for deleted or lost partitions, whether you’re on Windows or Mac. Plus, the interface won’t make you feel like you’re defusing a bomb—super beginner-friendly. Downside is, the free version limits your recovery, but hey, it’s a start, right?
Another one to eyeball is EaseUS Data Recovery Wizard—I can almost hear the wizard jokes starting. This thing can handle partition recovery too, and the three-step process is literally foolproof. Like, click here, scan there, done. BUT… 2GB on the free version won’t cut it unless your files are like, text documents and memes.
If you want a completely free solution and don’t mind feeling like a hacker in an old movie, there’s TestDisk. It’s open-source, does the job, but the command-line setup will either make you feel badass or want to throw your computer out the window. No in-between.
Tbh, I wouldn’t waste time with something basic like Recuva for full partition recovery—it’s more for single file pickups. And if you’re leaning towards Stellar Data Recovery, fair warning: it’s cool, but slower than a sloth doing yoga during a deep scan.
I’d say go Disk Drill or EaseUS if simplicity is your thing, and TestDisk if you’re feeling adventurous. Just don’t waste time downloading a bunch of bloatware that claims to be “FREE!!!”. More often than not, they’ll just tease you with previews and make you pay up anyway. Now, go get that partition back like a champ! :computer::crossed_swords:
Whoa, deleting an entire partition on your external hard drive? That’s like watching your digital life flash before your eyes. No worries though, you’re not in unfixable territory yet.
First off, I’m gonna challenge @mikeappsreviewer and @sterrenkijker a bit here. Disk Drill is legit solid, yeah, but ease of use doesn’t always mean ‘better’ for partition recovery. Sure, it’s super polished, and the partition search is pretty great for beginners, but if you’re after grit and raw power, the TestDisk option they mentioned might be where it’s at. It’s open-source, doesn’t charge you dime, and is specifically designed to tackle partitions, not just scattered files. Yes, the interface might make you feel like you’re defusing some encrypted virtual vault, but if you follow some tutorial videos, it’ll get the job done without screaming “paywall!” every five seconds.
Now, for the ‘click here, scan there, done’ crowd, EaseUS Data Recovery Wizard is indeed a no-brainer. Three steps and you’re back in action—unless you’ve got mountains of data over 2GB, in which case, you’ll have to cough up some cash. Personally, I lean a little cynical about free versions; most of the good stuff’s behind a purchase. But hey, if you only lost a small amount of critical files, give it a shot before pulling out your wallet.
Lastly, let me just say—skip tools like Recuva for this kind of job. (Yeah, I’m coming for Recuva, fight me.) It’s cool for grabbing individual files here and there, but partition recovery? Nah, harder pass than pineapple on pizza.
Alright, here’s my tl;dr advice: Try TestDisk if you’re comfortable nerding out with command lines (seriously, it might surprise you). If not, Disk Drill’s where you should start—slightly pricey for the full version, sure, but straightforward and dependable. And come on, nobody wants to spend more time fiddling than recovering. Just dive in!
For recovering a deleted partition, the software choice boils down to how techy you’re willing to get and how much time you have to tinker. Since you’ve lost an entire partition, not just individual files, your approach needs to have solid recovery depth. Here’s my take:
If you’re after a straightforward, user-friendly solution, go with Disk Drill. It’s basically the ‘plug-and-play’ of data recovery tools and consistently reliable for partition recovery. Pros: It supports over 400 file formats, has a clean UI (great for those of us who hate digging through messy menus), and adds features like Recovery Vault to preempt data loss in the future. Cons: It doesn’t really shine without the paid version; the free plan only gives you a taste (up to 500MB recovery). However, for those who appreciate convenience over cost, it’s worth the money.
Now, @jeff mentioned TestDisk. I’ll admit, it’s a beast for raw power. Totally free with a no-bull open-source model, it’s exceptional for lost partitions. The flip side? It’s not beginner-friendly. Using TestDisk feels like stepping into a hacker movie—command-line inputs everywhere, and one wrong entry could complicate your recovery attempt. So, unless you’re comfortable with something that looks more like “coding” than clicking “next,” Disk Drill is still your go-to.
As for @sterrenkijker’s mention of EaseUS Data Recovery Wizard—a solid suggestion if you’re juggling time and aren’t ready to commit money initially. It has a simple three-step recovery, and their partition recovery works decently for most scenarios. Downside? Free tier caps at 2GB, and deeper scans might take a while to churn through larger drives. Easier than TestDisk yet less nuanced than Disk Drill.
Final advice? Avoid Recuva for this—it’s a great file recovery tool but can’t handle partitions properly. If you’re on Windows and you don’t want to deep-dive into anything too complex, Disk Drill strikes the balance between functionality and ease-of-use better than most. If budget’s a constraint, give TestDisk a shot, but brace yourself for troubleshooting.
