What’s the best free project management tool right now?
I’m trying to organize tasks and deadlines for a small remote team and my budget is basically zero. I’ve tried a couple of free plans, but they either limit users, restrict key features, or become confusing as more projects are added. I need a genuinely free, easy-to-use project management tool that handles task assignments, due dates, and simple collaboration without hidden costs. What tools are you using that actually work long term for free, and why do you prefer them?
Short version for a small remote team with near zero budget:
  1. ClickUp Free
  2. Notion Free
  3. Trello Free
    Pick one based on how your team thinks.
Here is how they stack for your use case.
  1. ClickUp Free
    • Best “all in one” free plan right now.
    • Unlimited members.
    • 5 workspaces in free plan, 100 MB storage, but tasks, comments, and users are unlimited.
    • Features you get: list/board/calendar views, assignees, due dates, recurring tasks, simple automations, docs, reminders.
    • Strong for deadlines and multiple projects.
    • Downsides: UI feels busy, some stuff hides in menus. New folks need a bit of onboarding.
Suggested setup for your team:
• Space: “Company”
• Folders: “Client A”, “Client B”, “Internal”
• Lists inside folders: “Backlog”, “In Progress”, “This Week”, “Done”
• Create one Calendar view per folder, filter by “assignee = me” so each person sees their own deadlines.
• Use simple statuses only: To Do, In Progress, Blocked, Done.
  1. Notion Free
    • Strong if you mix docs with tasks.
    • Free plan has limited file uploads per user but plenty for text and light files.
    • Build one main “Tasks” database, then use views: board by status, table by assignee, calendar by due date.
    • Good for remote teams since you put meeting notes, SOPs, and tasks in one place.
    • Downsides: you need to design your own system, which takes time. People get lost if you overdo nesting.
Suggested setup:
• Top page “HQ”. Inside:
– Tasks (database)
– Meeting Notes
– Docs / Processes
• Fields for Tasks: Status, Owner, Due date, Priority, Project.
• Filtered views: “My tasks”, “This week”, “Overdue”.
  1. Trello Free
    • Easiest to start.
    • Unlimited members, but automation and power-ups limited on free.
    • Great for a single board or two, with a small team.
    • Problems start when you have many projects. You end up with 10 boards and no overview.
    • Good if your team likes cards and drag and drop and you keep things simple.
Suggested setup:
• One main “Team Board” instead of a board per project.
• Use labels for projects.
• Lists: Backlog, This Week, Today, In Progress, Review, Done.
• Each card: due date, assignee, project label, checklist for subtasks.
What I would do in your place:
• If your team struggles with clutter, pick Trello and accept that you keep everything on one or two boards.
• If you want docs + tasks in one place, and you like building systems, pick Notion.
• If you want a real project tool with strong free features and you can handle some complexity, go with ClickUp.
To avoid the confusion you mentioned:
• Standardize one workflow. Do not let each person create their own board or structure.
• Have one “Single Source of Truth” for tasks. No tasks live in DM, email, or random notes without a card/task entry.
• Run a 15 minute review once a week. Clean old tasks, archive done work, update due dates.
If you want almost no risk of hitting paywalls on core stuff, I would start with ClickUp, set up one simple space, keep statuses simple, and ban fancy features for the first month. Once the team is stable, add views and automations slowly.
If your budget is zero and your team is small + remote, the “best” free tool is honestly the one that stays simple for 6+ months instead of impressing you for 2 weeks and then turning into chaos.
@kakeru’s shortlist (ClickUp / Notion / Trello) is solid. I’d actually push a bit differently:
1. For pure task + deadline sanity: Asana Free
People sleep on Asana’s free plan, but for small teams it’s pretty solid:
  • Up to 10–15 ppl is usually fine before it feels cramped
  • Unlimited tasks, projects, messages
  • List, board, calendar view
  • Assignees, due dates, subtasks, basic dependencies via “waiting on” comments
Why it might fit you better than ClickUp:
  • Cleaner UI, less “feature soup”
  • Easier for non-techy teammates to grok in 10 minutes
  • Good at keeping multiple projects visible without juggling a jungle of workspaces
How to keep it simple:
  • One “Team” with 3–5 projects max (Client A, Client B, Internal, Admin)
  • Each project:
    • Sections: Inbox, This Week, In Progress, Blocked, Done
    • Use due dates on everything that actually matters
  • One rule: “If it’s not in Asana, it doesn’t exist”
2. If you actually live in chat all day: Slack + a simple board
Since you mentioned confusion as soon as projects scale, sometimes the meta-problem is “we have 5 tools and no one opens any of them.”
Minimal setup that works stupidly well for small remote teams:
  • Use Slack (free) as the communication hub
  • Pin one shared board from:
    • Trello, OR
    • Asana project, OR
    • ClickUp list
  • One channel per “project” and one channel #tasks where someone posts a link to every new task created
This avoids the “We created 12 boards and nobody updates any of them” syndrome. Central brain is chat, single board is the task spine.
3. If you’re okay being a bit “meh” about tools but want zero paywall pain: self‑hosted
You did say budget is basically zero, not literally zero. If you’ve got any cheap server or even a spare machine running:
  • Wekan (open source Trello-ish)
  • Focalboard / Mattermost Boards
  • OpenProject (heavier, more “PM manager” vibe)
Tradeoff: fewer sexy features, more long-term freedom, no “oh cool, we hit the free limit right at crunch time.” This is where I mildly disagree with @kakeru: instead of trying to squeeze a powerhouse like ClickUp into a free box and fighting its UI, you can just run something simpler that never locks stuff behind a paywall.
4. How to avoid the confusion you already hit (tool-agnostic)
The real trick is governance, not app features:
  • One hierarchy rule:
    • Projects are “buckets of work with a deadline”
    • Tasks are “one person’s clear next step”
  • One owner per project. No project with 0 or 2+ owners.
  • Weekly 20–30 min “systems cleanup”:
    • Close or archive all Done tasks
    • Kill or merge duplicates
    • Push any “someday” junk to a parking lot list
Honestly, for your case I’d do this:
  • If your team is not tool-nerdy: Asana Free
  • If you’re very docs-heavy & like building stuff: Notion Free, but be ruthless about keeping one main tasks database
  • If you want fine-grain control and can tolerate clutter and onboarding: ClickUp, like @kakeru suggested, but lock down who can create spaces/folders for the first 2 months
Whatever you pick, the “one source of truth” rule matters more than the logo at the top of the screen.
