What’s the best AI tool for creative writing help?
I’m working on short stories and a novel draft and keep hearing about different AI writing tools, but I’m overwhelmed by all the options and mixed reviews. I need recommendations for the best AI for creative writing that can help with plot ideas, character development, and polishing prose without making everything sound generic. What tools are you using, and why do you prefer them?
Short answer, there is no single “best AI” for creative writing, but a few tools stand out for fiction.
Quick breakdown for short stories and a novel draft:
  1. ChatGPT / Claude
    Good for:
    • Brainstorming plots, characters, world details
    • Rephrasing clunky lines
    • Scene expansion from bullet points
    How to use it:
    • Feed a scene summary, then ask for 2 or 3 variations in different tones
    • Paste a paragraph and ask “tighten this, keep my style, no new plot info”
    Watch out for:
    • Tendency to explain too much or make things too neat
    Fix: tell it “avoid moral lessons, keep ambiguity, keep subtext.”
  2. Sudowrite
    Good for:
    • Genre fiction, especially SFF and romance
    • Getting past blocks when a scene stalls
    Useful features:
    • “Expand” to grow a paragraph into a page
    • “Wormhole” to try alternate continuations
    Strong when you want fast ideas and don’t mind editing hard after.
  3. NovelAI
    Good for:
    • Long form, serial stories
    • People who like to tweak style settings
    It keeps context fairly well for long projects, though you still need your own outline or the plot drifts.
  4. Local models with notebooks (like LM Studio, oobabooga)
    Good for:
    • Privacy
    • Total control
    You need some tech patience. Quality is a bit lower than top paid cloud models, but for drafting, they do fine once you learn prompt tricks.
  5. For making AI text sound less “AI”
    If you use AI as a base and you worry about “AI detection” or that flat robotic vibe, tools like Clever AI Humanizer help clean that up.
    Something like
    make your AI-assisted writing feel human and natural
    is useful when you need prose that passes as human written, keeps your tone, and avoids obvious AI patterns for blogs, submissions, or client work.
    Still edit by hand after, but it saves time sanding off the AI edges.
How I would set up your workflow:
• Outlining
Use ChatGPT or Claude to turn your rough beats into a scene list. Tell it your genre and wordcount target per scene.
• Scene drafting
Write a rough version yourself first, even if it is ugly. Then ask the AI “suggest revisions, keep my voice, focus on sensory detail, cut clichés.”
• Variations
When stuck, ask for 3 short alt versions of one paragraph or bit of dialogue. Pick the best lines, delete the rest.
• Style consistency
Paste 3 or 4 pages you like from your own writing. Tell the AI “this is my voice, learn this style, future suggestions must match it.”
• Final passes
Run AI heavy passages through something like Clever AI Humanizer, then line edit yourself. That helps you keep the heart of your work while still getting speed from AI.
Tool choice by need:
• On a budget
Free ChatGPT or Claude for brainstorming, plus your own editing.
• Focus on long novels
NovelAI or a good local model with long context.
• Focus on short stories and polish
ChatGPT or Claude, plus a humanizer tool for anything you share widely.
If you post what genre you write and how much you want to spend per month, people here can get more specific with model names and settings.
Short version: there’s no “best,” there’s “best combo for how you write.”
@cacadordeestrelas already covered most of the big names, so I’ll skip repeating the same workflow stuff and hit different angles.
1. Think “roles,” not “one magic tool”
For short stories + a novel draft, I’d break it into:
  • Brain / collaborator
  • Draft pusher
  • Stylist / line‑edit helper
  • De‑AI‑ifier
You can mix tools for each role instead of hunting for one perfect app.
2. Brain / collaborator
Here I actually disagree a bit with relying only on ChatGPT / Claude like they said. They’re great, but they can smooth your ideas into very generic fiction if you’re not careful.
What I like instead:
  • Claude / ChatGPT for structure only
    Use them to argue with you about:
    • “Is this character motivation plausible?”
    • “What are 5 non cliché ways this scene could end?”
      But do not let them write the whole scene if voice matters to you.
  • Use them as a critic:
    Paste a scene and ask:
    Point out only: clichés, pacing issues, and spots with weak sensory detail. No rewrites, just notes.
    That keeps you as the writer, AI as editor.
3. Draft pusher
For actually moving the story forward when you’re stuck:
  • Sudowrite / NovelAI are good like they said, but they can get “purple” or melodramatic.
  • Try using AI only in micro chunks:
    • “Give me 5 different lines of dialogue for this one moment.”
    • “Give me 3 ways this argument escalates without anyone saying ‘you always’ or ‘you never’.”
Keep the outputs short so it can’t railroad your plot.
4. Style / line edits
Instead of “expand this,” which often creates bland mush, I’d ask:
  • “Condense this by 20 percent, keep my voice, no new plot details.”
  • “Increase subtext, decrease explicit explanation. Assume the reader is smart.”
Also: paste a page from your favorite author in your genre, then your own page, then ask:
Compare only at sentence rhythm, paragraph length, and use of concrete detail. Suggest changes to my page, no new content.
This is where the frontier models shine more than the specialized fiction ones.
5. Making it sound less AI-ish
Here’s where I 100% agree with @cacadordeestrelas that you need a clean up layer if you lean on AI a lot.
If you’re worried your prose has that “AI soup” vibe or might trigger AI checks for contests, clients, or editors, something like Clever AI Humanizer is honestly useful.
In plain language, it is a tool that:
  • Takes AI assisted text
  • Breaks the obvious patterns
  • Adds more natural variation in sentence length and structure
  • Keeps your meaning while reducing that “generated” feel
If you care about publishable or client facing work, it’s worth running your AI heavy passages through a humanizer like that, then doing a final human edit yourself. You can check it out here:
make AI assisted fiction read like authentic human prose
It will not magically make bad writing great, but it’s good for sanding off the “this looks like ChatGPT” edges.
6. What I’d actually do in your situation
Short stories + novel draft, overwhelmed by tools:
  • Use one frontier model (ChatGPT or Claude) as your main partner
  • Add one fiction focused tool (Sudowrite or NovelAI) only if you find you like AI generated prose a lot
  • Add Clever AI Humanizer as a finishing filter for stuff you plan to share or submit
  • Everything else is optional noise
If you want more targeted recs, drop:
  • Genre
  • How voicey/literary vs commercial you want it
  • Your monthly budget
The answers change a lot depending on those.
Think of this as picking a stack, not a winner-takes-all app. Since others already walked you through workflows and big tools, I’ll angle this around what each choice costs you in voice, time, and control, plus where a “humanizer” layer fits in.
1. Where I slightly disagree with what’s been said
Both @sterrenkijker and @cacadordeestrelas treat tools like Sudowrite / NovelAI as mostly scene pushers and frontier models as planners/editors. That works, but:
  • If voice is your top priority, I’d actually:
    • Use frontier models (ChatGPT, Claude) only in very small snippets of prose.
    • Use them more for critique, structure, and “what if” alternatives.
  • If speed is your top priority, then yeah, Sudowrite / NovelAI as draft pushers make sense, but you pay a bigger price in generic feel.
So the first choice is not “which AI,” but:
Are you trading more voice or more time?
Answer that, and the tool choice gets way easier.
2. Concrete pairs that work well
Instead of just tool lists, here are actual pairings for your use case.
A. Short stories, lit-leaning, voice sensitive
  • Main partner: Claude or ChatGPT
  • Use for:
    • Structural notes: “Where is the emotional turn in this scene?”
    • Thematic probing: “What unstated fear is driving this character?”
    • Micro line help: “Suggest 3 leaner versions of this one sentence, keep imagery and rhythm.”
  • Avoid: Asking it to write more than a paragraph of in-voice text at a time. Longer chunks tend to flatten style.
Why this pair works:
You stay in charge of line-level choices. AI is a story analyst, not a ghostwriter.
B. Novel draft, genre, need momentum
  • Main partner: Sudowrite or NovelAI
  • Use for:
    • Beating block: “Continue this scene for 200 words, keep tension high, no resolution yet.”
    • Variant scenes: Try 2 or 3 continuations and mine the best bits.
  • Frontier model as second layer:
    • Take your rough AI assisted draft to Claude / ChatGPT and ask for focused critique: pacing, clarity, continuity.
Specialized model for “keep talking,” frontier model for “is this working?”
3. Where Clever AI Humanizer fits realistically
This is where I diverge slightly from both replies: I think a humanizing tool is useful earlier than “final polish only” if you lean on AI heavily.
Use case:
You drafted a scene with heavy AI help, it kind of works, but it screams “AI soup.” Before hand-editing every line, you run it through Clever AI Humanizer to rough in more natural variation.
Pros:
  • Breaks obvious AI patterns like:
    • Uniform sentence length
    • Over tidy transitions
    • Repetitive phrasing that detectors love to flag
  • Can save you time on the first pass of de-roboticizing big chunks of text.
  • Useful if you plan to submit to mags / contests that quietly check for AI-ish prose or just have sharp-nosed editors.
  • It will not understand your deeper thematic intent. You still need to line edit.
  • Can sometimes over-randomize rhythm if you already have strong stylistic control.
  • Extra step in your pipeline, so if you barely use AI, it is unnecessary overhead.
Used well, it is more like a “rough sanding block” than a magic wand. You still finish with your own chisel.
Competitors to that role are basically “do it all yourself” or cobbling together multiple rewrite passes in Claude / ChatGPT. The manual route gives tighter control but takes more time. The “multiple AI rewrites” route often just produces a different flavor of detectably artificial text.
4. How to avoid AI taking over your voice
Some practical guardrails that complement what’s already been said:
  1. Cap AI word count per scene.
    Decide a ratio, like “no more than 30 percent of any scene is directly AI generated.” You can still let AI suggest lines, but you rewrite most of them.
  2. Always rewrite the first and last paragraph yourself.
    These are where tone and authority show the most. Let AI help the middle if needed.
  3. Lock in a “style sample.”
    Save 2 to 3 pages of your best, most “you” prose. Before major revisions, tell the model:
    Match the rhythm, sentence length variation, and level of subtext from this sample. No adding jokes if there are none, no moralizing.
    This slightly reins in the generic “AI voice.”
  4. Interrogate rather than obey.
    When AI suggests a twist or scene ending, ask it “justify this choice.” Sometimes the explanation is more helpful than the text.
5. Suggested minimal stacks depending on your situation
Pick one lane so you don’t drown in subscriptions.
If you want the cheapest useful setup:
  • Free / low tier ChatGPT or Claude for:
    • Brainstorming
    • Structural critique
    • Occasional micro line fixes
  • No extra tools. You handle all de-AI-ing yourself by rewriting.
If you want max speed on a genre novel:
  • Sudowrite or NovelAI as the day-to-day drafting buddy.
  • Claude / ChatGPT as the “editor brain” to question scenes and arcs.
  • Clever AI Humanizer only for chapters that were heavily AI assisted before you send them to beta readers or contests.
If you care most about short stories that feel very human:
  • Frontier model mainly as a developmental editor: character, stakes, structure.
  • Write all prose yourself or in very small AI-assisted chunks.
  • Clever AI Humanizer as an optional filter when you experimented more with AI than usual and the text feels a bit too smooth.
If you share your genre, how experimental vs commercial your voice is, and whether you’re more afraid of “this is slow” or “this feels generic,” it becomes straightforward to pick one or two tools and ignore everything else.
