I was set on buying an RTX 4070, but now I’m seeing a lot of talk about the RTX 5070 and I’m not sure which one makes more sense. My current GPU is struggling with newer games at 1440p, and I need help comparing performance, price, power use, and long-term value before I spend the money.
If you need a card now, get the 4070 only if the price is low enough. I’d say closeout pricing or used pricing. If the 5070 is anywhere near launch MSRP, it makes more sense for 1440p.
What matters for you:
- Raw fps at 1440p.
- VRAM.
- RT and upscaling support.
- PSU and case fit.
The 4070 is still fine for 1440p high settings. It does well in stuff like Cyberpunk, Alan Wake 2, Helldivers 2, all with some settings tuning. But 12GB VRAM is already a weak spot in a few newer games if you push textures and RT. That part matters more going forward.
The 5070 should give you better longevity. Newer architecture, better RT, better frame gen, and likely stronger 1440p ultra performance. That’s the smarter upgrade if you keep GPUs for 3 to 5 years.
Easy rule:
If 4070 is much cheaper, grab it.
If prices are close, take the 5070.
If your current GPU is dying and you need somthing now, don’t overthink it and hunt the best 4070 deal.
Also check your PSU. Don’t buy first, then figure out your power cables later.
I’d lean 5070 unless the 4070 is a legit bargain, and I mean actually cheap, not “$30 less so it’s on sale lol.”
Where I kinda differ from @viajeroceleste is on urgency. I would not rush into a 4070 just because your current card is suffering. If it still functions, even badly, I’d wait a bit and see real 5070 pricing and benchmarks in the games you play. Launch hype always muddies the water.
A few things people forget:
- resale value matters if you upgrade often
- newer gen cards usually hold value better for the first couple years
- driver support and feature updates tend to favor the newer card
- if you use DLSS/frame gen at 1440p, the newer option is probly the better long-term bet
That said, the 4070 is not some useless dinosaur. It’s still a very solid 1440p card. The problem is buying one too close to 5070 pricing. That’s the trap.
My dumb-simple take:
- 4070 at a steep discount: buy it
- 5070 within reach: wait and get that
- buying used: 4070 gets way more interesting
Also check CPU pairing. If you’re on an older midrange CPU, the 5070 advantage might not feel as huge in some games. That part gets ignored al ot.
