Need help deleting an old Facebook business page
I have an old Facebook business page that I no longer use, and it’s confusing my customers because it still shows up in search results. I’ve tried looking through Facebook settings, but I can’t find a clear way to permanently remove or deactivate the page. Can someone walk me through the exact steps to safely delete a Facebook page and make sure it doesn’t appear publicly anymore?
Had to do this for an old client page, Facebook hides it a bit. Here is the step by step.
  1. Make sure you are an admin
    • Go to the old page
    • Click your profile picture top right
    • Switch to the old business page profile
    • If you cannot switch, you are not an admin and you need ownership first
  2. Open the page settings
    • While using the page profile, click your profile picture top right
    • Choose “Settings & privacy”
    • Click “Settings”
    • In the left menu, pick “Privacy” or “Your Facebook information”
    Facebook moves this around, so look for “Access and control” or “Deactivation and deletion”
  3. Delete the page
    • Click “Access and control”
    • Click “Deactivation and deletion”
    • Choose “Delete Page”
    • Confirm a few times. It goes into a 30 day grace period. During this period you can still restore it
    • After 30 days Facebook removes it from normal view. Old search results in Google can stick for a bit longer
  4. If the page was auto generated from a place
    Sometimes Facebook creates “unofficial” place pages when users check in
    • Open the page
    • If there is no “Settings” option or you see “Is this your business” then click that
    • Go through the “Claim this page” process
    • Once you own it, repeat steps above to delete
  5. Reduce confusion in search while you wait
    • Update the old page name to “Old / Closed / Do Not Use”
    • Change the profile and cover photos to something that says “Closed”
    • Put a big note in the About section with a link to your correct page or site
    • Unpublish instead of delete if you only want it hidden inside Facebook
    Go to Settings, then “Page visibility”, choose “Unpublish”
  6. Clean up search results
    • For Google, request removal of outdated links
    Go to “Remove outdated content” in Google Search Console tools
    • Add clear info about your real page on your website so users recognize it faster
If something in the menu looks different, Facebook often shows two layouts at the same time. Try both paths:
• From the page home, click “Settings” at the bottom of the left sidebar
• Or from your profile picture top right, switch to the page, then “Settings & privacy” then “Settings” again
This process fixed customer confusion for my client in about a week. Search snippets for the old page faded from Google over a few more weeks.
Couple of extra angles you can try that go around Facebook a bit, since @techchizkid already nailed the internal steps.
  1. Check if the page is actually “owned” by Meta Business Suite
    Sometimes the page is controlled from Business Manager and you’ll never see the delete option in normal Facebook.
    • Go to business.facebook.com while logged in
    • See if the old page shows up under “Business settings” → “Accounts” → “Pages”
    • If it’s there, remove it from that business (or transfer ownership to your main business) first, then try deleting / unpublishing from the normal Page interface again.
      If it’s stuck in an old Business Manager you no longer access, this is often why the menus seem broken or missing.
  2. If you cannot get admin at all
    This is where I slightly disagree with the idea that you must own it to fix confusion. Owning it helps, but:
    • Use Facebook’s “Report Page” and choose “Fake page” or “Impersonating a business”
    • In the report, paste the URL of your real page and explain that the old one is outdated / abandoned and confusing customers
    • Get a few coworkers or friends to report the same way. Multiple consistent reports sometimes trigger actual review faster.
      This is hit or miss, but I’ve seen dead pages removed this way when access was impossible.
  3. Tackle the Google problem directly
    The confusion usually happens in Google, not inside Facebook. While you wait on deletion (or if Facebook drags its feet):
    • In Google Search, search for the exact business name + “Facebook”
    • Next to the wrong result, click the 3 little dots → “Report issue” or “More” and look for “Outdated content” / “Remove result”
    • If you control a website with your correct page linked, Google is more likely to understand which result is the “real” one over time.
      Also change your site, email signatures, and any directories so they all point to the correct page. That indirectly downranks the old one.
  4. Use name & category to your advantage
    Instead of just “Closed” in the title like @techchizkid suggested, I usually go obnoxiously clear:
    • Page name: “OLD PAGE – DO NOT USE – See New Page: [New Name]”
    • Category: remove anything that makes it look like an active business (set to generic or “Community”)
    • Website field: link to your real page or website, all caps description like:
      “THIS PAGE IS NO LONGER USED. CURRENT PAGE: https://facebook.com/yourrealpage”
      It looks ugly, but ugly is the point: users bounce faster, Google eventually demotes it.
  5. Check for connected assets that keep it “alive”
    Sometimes the page stays “active” in Meta’s eyes:
    • Open Ads Manager and make sure there are no inactive ad accounts still tied to that page
    • Disconnect Instagram profiles, WhatsApp business numbers, booking tools, etc.
      A “clean” page is easier to delete or at least deprecate.
  6. If you’re really stuck
    Last resort, but it has worked:
    • Use the “Help & support” → “Report a problem” from the Facebook app
    • Choose “Pages” as the issue
    • Spell it out:
      • Old page URL
      • New page URL
      • Short note: customers are being misled, you no longer have access, requesting removal or merge
      Don’t write an essay, but be very specific. Sometimes they offer a merge when deletion is awkward.
You’re not crazy, Facebook honestly makes this harder than it should be. The combo that usually fixes it for my clients: rename the old page clearly, strip categories, blast your real page everywhere else, and then slowly wrestle with Meta to delete or merge in the background.
Couple of angles that haven’t been hit yet, focusing on reducing damage while Facebook and Google catch up.
1. Consider merge instead of pure delete
Both @caminantenocturno and @techchizkid focused on deletion / unpublishing, which is valid, but sometimes a merge gives you a cleaner result in search:
  • Requirements (roughly, Meta changes rules often):
    • Same or very similar name
    • Same business / location category
    • You must be admin on both pages
  • If you qualify, go to your main page → Settings → look for “Merge Pages” or “Combine pages”.
Why merge?
Pros:
  • Old followers get moved to the correct page, so you reclaim audience.
  • Old URL often redirects to the new page instead of a dead result.
  • Google usually updates faster because the old result now resolves to something valid.
  • If the old page has bad reviews, some of that reputation can carry over.
  • If info is very inconsistent (name, address), Meta may reject the merge.
If reviews on the old page are awful, deletion or unpublishing may be safer than merging.
2. Stop “reconfirming” the old page to Google
A subtle mistake people make while trying to fix this:
  • Constantly clicking the old result from Google to “check if it is still there.”
  • Linking to that old page from emails or third‑party profiles “until it’s gone.”
Google uses click data and backlinks as hints. Every time you or customers keep landing on the old URL, it signals “still relevant.”
Instead:
  • Remove that old URL from everywhere you control: website footer, email signatures, booking tools, directory listings.
  • When you must reference it (like in a Facebook support ticket), do it inside Meta only, not on public pages where crawlers pick it up again.
3. Lean on NAP consistency to push the right entity
A lot of the confusion happens because Google is unsure which “entity” is your real business presence.
Make your current page the obvious main one:
  • Ensure your business Name, Address, Phone (NAP) on:
    • Website
    • Google Business Profile
    • Major directories
      all match exactly what is on your current Facebook page.
  • On those same profiles, do not list or link the old page at all.
Over time, this consistency helps search engines devalue the old page in results without you needing to win every fight inside Facebook.
4. Don’t overdo the “Closed” messaging
Here is where I slightly disagree with both approaches. Renaming the page to things like “OLD / CLOSED / DO NOT USE” is practical inside Facebook, but:
  • If someone searches your brand and sees “Closed” next to it in a rich snippet, they may think the entire business is gone.
  • That label can also get scraped into other listings automatically.
If you go this route, I keep it more balanced:
  • Page name: “[Business Name] – Old page, see current profile”
  • First line of About: “This page is archived. For current info, search Facebook for ‘[Business Name] Official’.”
Still clear, but less likely to scare off new customers at a glance.
5. Short note on “product” style fixes
Sometimes people look for some magic product or plugin that just “removes” an old Facebook business page from search. Pros and cons of that general idea:
Pros:
  • Can save time if it automates requests to search engines for outdated content.
  • Helpful dashboards can show where the old URL is still listed across the web.
  • None of these tools can actually delete the page from Facebook itself. That always goes through Meta.
  • If your website and profiles keep pointing at the wrong URL, any tool becomes a band‑aid, not a fix.
So any product like that works only if you first clean up your own citations and only then use it as a clean‑up assistant, not as the main solution.
6. When support is slow, think “containment”
While you wait for Meta or search engines:
  • Pin a post on your active page that clearly shows your logo and wording like “This is our only current Facebook page.”
  • Use that same line in your email auto‑signatures and on your website contact page.
  • In messages or auto‑replies, tell people “If you see any other Facebook page with our name, ignore it.”
That way, even if the old page lingers a bit, most new customers are nudged to the right place.
Between the detailed in‑Facebook steps from @caminantenocturno, the extra routing ideas from @techchizkid, and these cleanup / merge / search‑behavior tweaks, you should be able to get the old page out of the way without losing real customers in the meantime.
