Need help connecting to Deltawifi.com wifi on my device
I’m having trouble getting my device to connect to Deltawifi.com wifi. The network shows up, but the connection keeps failing or dropping, and I’m not sure if it’s a login, settings, or compatibility issue. I need help figuring out what to check, how to properly sign in, and any steps to fix common Deltawifi.com connection problems so I can get stable internet access again.
Happens a lot on Deltawifi, so here is a checklist that usually fixes it or at least makes it usable.
  1. Forget and re-add the network
    • On your phone or laptop, go to Wi Fi settings.
    • Tap the Deltawifi.com network, choose “Forget” or “Remove”.
    • Toggle Airplane Mode on for 10 seconds, then off.
    • Connect again, wait for the captive portal page.
  2. Force the login page to load
    Many devices fail to pop the portal.
    After you connect to Deltawifi.com, open a browser and go to:
    • neverssl.com
    • 1.1.1.1
    • example.com
    These are plain HTTP sites, so the redirect to the Delta login usually works.
  3. Turn off VPN, DNS apps, ad blockers
    • Disable any VPN. Deltawifi often blocks or breaks them.
    • Turn off private DNS / custom DNS (like 1.1.1.1 app, NextDNS, etc).
    • Turn off system wide ad blockers or “secure browsing” features.
    These tools interfere with the captive portal redirect and session.
  4. Check device compatibility settings
    • If you use Android, go to Wi Fi network details, make sure:
    – “Use randomized MAC” is off, use phone MAC instead.
    – Proxy is set to “None” unless your company profile changed it.
    • On iOS, under the network:
    – Turn off “Private Wi Fi Address”.
    – Turn off “Limit IP Address Tracking”.
    Airline portals often track by MAC and IP, so these toggles break logins or kick you off.
  5. Use only one device at a time
    Some flight plans limit how many devices connect on a single purchase.
    • Log out on other devices first.
    • If there is no logout button, forget the network on the old device and power its Wi Fi off.
    • Then reconnect from the device you want to use.
  6. Try a different browser
    • Use Chrome, Edge, or Safari with no extensions.
    • Disable “HTTPS only” or “Secure by default” modes.
    • Clear cache for deltawifi.com and gogoair.com if listed.
    Older captive portals break with strict HTTPS rules.
  7. Fix constant drops
    If you get connected but it keeps dropping:
    • Stay seated while you test. Moving around can put you at a bad angle to the access point.
    • Avoid heavy streaming. Use lower quality video.
    • Turn off background sync on apps like OneDrive, Google Drive, Steam, game launchers.
    Lots of background traffic triggers portal issues or throttling.
  8. Check if the network is overloaded
    On busy flights speeds drop and connections flap.
    If you use a laptop, a tool like NetSpot can help you see signal strength and channel use.
    You can use NetSpot Wi Fi analyzer to check if your signal is weak compared to other seats or if your adapter acts up.
    The same tool is pretty helpful at home or in hotels too, for spotting weak spots and tuning your router.
  9. Quick device specific tweaks
    Windows:
    • Right click Wi Fi icon, “Open Network & Internet settings”.
    • Disable then enable the adapter.
    • In Device Manager, under your Wi Fi card properties, Advanced tab, set:
    – Preferred band to “No preference” or “2.4 and 5 GHz”.
    – Roaming Aggressiveness to “Medium”.
    macOS:
    • Hold Option, click Wi Fi icon, choose “Disconnect from Deltawifi.com”, then reconnect.
    • If it keeps failing, create a new location in Network settings and reconnect.
If you reply with your device type and OS version, plus when it fails (at connect, at login page, or after a few minutes), people here can narrow it down more.
Deltawifi is… temperamental. @chasseurdetoiles covered most of the “normal” stuff, so I’ll skip the repeat and hit some edge cases that bite people a lot.
First, a cleaner version of your issue so others can find this later:
You’re trying to connect your phone, tablet, or laptop to Deltawifi.com on a flight. The Wi Fi network appears in the list, but the connection either fails immediately, never shows the login page, or keeps dropping after a few minutes. You’re unsure if it’s a login problem, Wi Fi settings issue, or a compatibility conflict with your device.
Now, extra things to try that weren’t really covered:
  1. Check if the radio is actually stable
    Sometimes the Wi Fi chip is just freaking out, especially on Windows and some Android phones.
    • Toggle Wi Fi off for a full 30 seconds, not 2 or 3.
    • If on a laptop, completely reboot instead of just closing the lid. Sleep/hibernate often keeps a bad network state.
    • If you recently used a wired VPN or dock, those “virtual adapters” can confuse captive portals. Disable any extra adapters in Network settings temporarily.
  2. Watch the network name closely
    Delta sometimes shows multiple SSIDs on certain aircraft types. If you see “DeltaWiFi.com” and also a generic “gogoinflight” or similar:
    • Try the one that actually matches the portal URL mentioned in the onboard instructions.
    • If your device is trying to auto join an old inflight SSID from a different airline, it can latch onto the wrong one and never get the correct portal.
  3. When the login page never appears even with HTTP sites
    You already saw @chasseurdetoiles mention neverssl and 1.1.1.1. If those still don’t launch the page:
    • Manually type http://deltawifi.com and also http://gogoinflight.com in the browser address bar.
    • Turn off “Use secure DNS” or “Encrypted DNS” at the browser level too. Chrome/Firefox can override system DNS and still block the redirect.
    • On Chrome, try an incognito window so cached redirects and cookies don’t mess things up.
  4. Purchase / session glitches
    This one is ugly but real: sometimes the payment or login session gets half registered. Symptoms: it lets you in for 30 to 90 seconds then boots you with “you’re already logged in on another device” or similar.
    • Use the same browser and same device you used to purchase and go back to the portal’s “manage device” or “log out” page if it exists.
    • If you can’t find it, completely close the browser (force quit on mobile), then reconnect and see if it prompts you again.
    • Worst case: switch browsers on the same device. It sometimes forces a clean session.
  5. For really stubborn Windows issues
    If you can connect to the SSID but no traffic works:
    • Open Command Prompt as admin:
      • ipconfig /release
      • ipconfig /renew
      • ipconfig /flushdns
    • Then re-open the browser and try an HTTP site again.
    • Also check if you have any “corporate” security suite installed (Zscaler, Cisco AnyConnect in “always on” mode, etc). Those are notorious for blocking captive portals; you may need to temporarily disable or pause them.
  6. For macOS and iOS oddities
    I mildly disagree with always turning off every privacy toggle forever like some people suggest. It’s fine for the flight, but remember to turn stuff back on later. More surgical approach:
    • On iOS: if it fails once, tap the “i” next to DeltaWiFi, disable Private Address and Limit IP Tracking only for that network, then try again. After the flight, forget that specific network so your privacy defaults go back to normal.
    • On macOS: under Network > Wi Fi > Advanced, drag DeltaWiFi to the top so it connects to that first, not some airport or lounge network you used earlier.
  7. Physical / RF issues
    Even if the SSID shows up, the signal at your seat can be trash. Especially if you’re near the galley or bathrooms or at the very back.
    • If you have a laptop, walk the aisle briefly (when allowed) and see if the signal improves a lot a few rows away. If yes, it is literally just a bad RF spot.
    • At home or in hotels, a tool like NetSpot is great for mapping these weak zones and channels. On flights you can’t fix the access point placement, but you’ll clearly see if your adapter keeps dropping signal or if the environment is just noisy.
    If you’re curious how Wi Fi coverage looks in other scenarios, visualizing and troubleshooting your Wi‑Fi coverage with NetSpot is pretty eye opening.
  8. When nothing works and you’re losing your mind
    • Toggle Airplane mode on. Leave it for at least 30 seconds. Turn Wi Fi on while still in Airplane mode.
    • Try a totally different device for comparison (even if you don’t plan to use it long). If that second device connects fine, the problem is 99 percent your original device config.
    • If no one around you can get on, the access point or backhaul is probably down. No setting fix will help at that point.
If you can post your device type (Windows / macOS / iOS / Android), approximate version, and at which exact step it fails (won’t join SSID, joins but no page, or drops after login), people here can usually pinpoint the culprit pretty fast.
Two solid posts already from @waldgeist and @chasseurdetoiles, so I’ll stick to a few extra angles they didn’t really dig into and push a bit on what I see people overlook with Deltawifi.com.
1. Check for “enterprise junk” on your device
If this is a work laptop or a phone with company MDM:
  • Look for always‑on VPNs (Zscaler, GlobalProtect, AnyConnect, etc) that cannot be paused easily. Some of these intercept all traffic before the captive portal and Delta’s system just gives up.
  • If possible, switch to a personal device for the flight. Deltawifi plus corporate security stacks is a very fragile combo.
2. IPv6 can be the silent killer
Deltawifi portals are often still IPv4‑centric:
  • On Windows or macOS, temporarily disable IPv6 on that Wi‑Fi interface and reconnect.
  • On Android, some ROMs let you force IPv4. If you have that setting, try it for the flight.
This is one place I slightly disagree with the “just reset everything and hope” approach. Targeting IPv6 alone breaks fewer things and often fixes weird no‑portal issues.
3. Watch your background traffic
Even after you are in, heavy sync can make it look like “constant drops”:
  • Disable auto‑updates for Steam, Epic, cloud backup, OS updates, Apple Photos / Google Photos for the duration of the flight.
  • If the portal thinks you are abusing bandwidth, it may throttle or temporarily bump you.
4. Browser profile issues
If you have a super locked‑down browser profile:
  • Create a fresh browser profile or use a different browser entirely instead of just using incognito.
  • Some security extensions still run in incognito and break redirects. A clean profile is a good baseline test.
5. NetSpot for sanity checks
On laptops, something like NetSpot is actually useful even on a plane:
  • Pros:
    • Shows signal strength and noise so you can see if your seat is just in a bad RF pocket.
    • Lets you compare Deltawifi.com vs other visible networks to confirm your adapter is not the weak link.
    • Very handy later at home or hotels for mapping dead zones and tuning your own router.
  • Cons:
    • Not magical: it cannot fix Delta’s backhaul, only help you see where the problem likely is.
    • More useful on laptops than phones, so if you are only on mobile it is limited.
    • Can feel like overkill if you just want to check email for a short flight.
If NetSpot shows strong signal and clean channels but you are still getting disconnects, you can be pretty confident the bottleneck is on Delta’s side, not your hardware.
6. Use the other posts as a checklist, then narrow down
  • Start with the basic portal, VPN, MAC address, and privacy toggles that @chasseurdetoiles listed.
  • Layer on the more “edge case” tricks from @waldgeist for adapter resets and session issues.
  • If you still cannot stay online, add the IPv6 tweak and check for corporate VPNs or security agents.
From there, if you share device type, OS version, and the exact failure point (fails at join vs no portal vs drops after 1–2 minutes), people can give much more targeted advice instead of more generic “try everything” lists.
Alternative, simpler path: use your phone as a bridge with USB tethering.
  1. Set phone to airplane mode. Enable wifi. Join Deltawifi.com, complete portal.
  2. Plug phone into laptop. On Android, toggle USB tethering. On iPhone, enable Personal Hotspot, connect via USB only, keep wifi hotspot off.
  3. Use the laptop thru the phone. Bluetooth PAN also works, about 2 to 3 Mbps, ok for email and docs.
This bypasses strict laptop stacks, VPN clients, and IPv6 quirks. It isolates the captive portal to the phone, which tends to behave better on Delta.
