Need help choosing the best apps for productivity and daily tasks
I’m overwhelmed by the number of apps for productivity, note-taking, and task management. I’ve tried a few, but they either feel too complex or lack key features like syncing across devices, offline access, and good reminders. I’d really appreciate recommendations on reliable apps that actually work well in real life and won’t waste my time switching again.
I went through the same overload spiral. What helped was picking a tiny “stack” and forcing myself to stay with it for 30 days.
Here is a simple setup that hits your requirements. Sync across devices, offline, reminders, not bloated.
  1. Tasks and reminders
    Use: Microsoft To Do or Todoist
Microsoft To Do
• Free, solid sync, good on Windows, Mac, iOS, Android, web
• Offline works fine on phone and desktop
• Natural language due dates: “pay rent tomorrow 9am”
• Shared lists for family or work
• Simple enough that you do not need a YouTube course
Todoist
• Better for recurring tasks and projects
• Great natural language: “every 3rd weekday at 4pm”
• Offline on all platforms
• Labels and filters once you want more control
• Free is enough for most people
Pick one. Do not use both.
Setup tip:
• Create 3 main lists: Today, This week, Later
• Everything goes into Inbox, then you sort into those
• Set a time at night to review tomorrow and clean up
  1. Notes and reference stuff
    Use: Standard Notes or Apple Notes or Google Keep, depending on devices.
Standard Notes
• Works on all platforms
• Strong privacy, offline by default, syncs when online
• Simple folders and tags
• Good for text notes, checklists, journaling
Apple Notes (if you are on Apple only)
• Deep integration with iOS and macOS
• Offline by default with iCloud sync
• Attach PDFs, photos, sketches
• Fast search
Google Keep
• Very simple, sticky-note style
• Great for quick ideas and checklists
• Works well on Android and web, offline on mobile apps
Setup tip:
• One “Inbox” note for quick brain dumps
• One “Projects” note with links to related notes or docs
• Use simple tags in title like “#health”, “#work” so search finds stuff fast
  1. Calendar and time
    Use: Google Calendar or Apple Calendar
You do not need fancy features.
• One calendar for personal, one for work
• Put time-blocks for deep work, errands, workouts
• Syncs across devices, works offline on mobile apps
  1. Basic workflow to avoid chaos
    Morning
    • Check calendar
    • Open task app, choose 3 main tasks for today, star them
During day
• New idea or task goes straight into task Inbox or notes Inbox
• Do not organize on the spot
Evening
• 5–10 min review
• Move task Inbox items into Today, This week, Later
• Archive or delete stuff you no longer care about
  1. Apps to avoid at first if you feel overwhelmed
    • Notion, Obsidian, ClickUp, Roam, etc
    They are strong, but they invite tinkering and rabbit holes. You end up managing the system instead of doing work. Ask me how I know, lol.
  2. Decision cheat-sheet
    If you want:
    • Easiest combo: Microsoft To Do + Google Calendar + Google Keep
    • Apple-only: Apple Reminders + Apple Calendar + Apple Notes
    • Cross-platform with more control: Todoist + Google Calendar + Standard Notes
Give your setup 30 days without switching. Take notes about what annoys you. After that, change one piece at a time, not the whole stack.
If you share your devices and if you work more in browser or in apps, people here can suggest a tighter combo.
You’re not crazy, the app zoo is real.
I like a lot of what @nachtdromer said about running a small “stack” for 30 days, but I actually think people overcomplicate the choice itself. You don’t need “the best” app. You need the app you’re least likely to abandon on a tired Tuesday.
Here’s a different angle:
  1. Pick one “spine” app
    Instead of 3 separate tools (tasks + notes + calendar), choose one thing that feels like “home base” and let the others be boring utilities.
    Example options:
    • If you live in email: use Outlook or Gmail as the spine, then:
      • Starred emails = tasks
      • Calendar = appointments only
      • A dead-simple notes app = reference
    • If you live in chat: use Slack or Teams as the spine:
      • Save messages to a “Later” or “Saved” list as tasks
      • Calendar just for time slots
      • Notes app only for stuff you truly need to keep
    The point: you always ask “Where does this go?” and the answer is almost always the same app.
  2. Use one tool in “dumb mode”
    Everyone says Todoist / To Do, etc., which is fine, but most people drown in features. Whatever you pick, try:
    • No tags
    • No priorities
    • No projects
    • Just:
      • Inbox
      • Today
      • This Week
    The “system” can come later. Right now you’re building the habit of actually checking it.
  3. Go heavier on calendar, lighter on tasks
    Here I slightly disagree with @nachtdromer. Many people shove everything into a task app, never look at it, and feel like failures.
    Try this split:
    • If it takes longer than 30 minutes, it’s a calendar event, not a task
      “Write report” → 2 × 45min blocks in your calendar
    • If it takes under 10 minutes, it’s a task
    • If it’s just “nice to do someday”, it’s a note, not a task
    This keeps your task list from turning into a wish list.
  4. Notes: think “scratchpad” not “second brain”
    People waste weeks building cute note systems. You do not need backlinks, graph views, or advanced markdown to remember “which plumber I used last year”.
    My suggestion:
    • One folder called “Scratch”
    • One folder called “Reference”
    • A single pinned “Inbox” note for random stuff during the day
      Once a week, move anything worth keeping from “Scratch” to “Reference”. Delete the rest. Ruthless > organized.
  5. Sync & offline without gadget drama
    To hit your actual requirements:
    • You use mostly Apple stuff:
      • Reminders + Notes + Calendar already do:
        • Sync, offline, reminders, attachments
    • You’re mixed / cross platform:
      • Tasks: Todoist or Microsoft To Do
      • Notes: Standard Notes or simple Markdown files in a synced folder (iCloud, Google Drive, etc.)
      • Calendar: Google Calendar in whatever client
    If switching devices is a big part of your life, prioritize how fast it opens over features. A “meh” app you open daily beats a “perfect” one you ignore.
  6. Hard constraints so you stop app-hopping
    For the next 30 days:
    • You’re allowed:
      • 1 app for tasks
      • 1 app for notes
      • 1 app for calendar
    • You are not allowed:
      • To install a new productivity app “just to try it”
      • To reorganize everything after watching a YouTube productivity guru
    Write this rule literally in your notes app:
    “I am not allowed to fix my system during work hours. Only use it.”
  7. When to actually change apps
    After 3 or 4 weeks, only consider switching if:
    • Sync is unreliable
    • Offline actually fails
    • You keep forgetting to open it even after reminders
    If the problem is “I could organize better with tags and templates,” that is usually not a tool problem. That’s procrastination wearing a productivity hoodie.
TL;DR version:
Stop searching for “the best” app. Pick one simple task app, one boring notes app, and let your calendar carry more weight. Stick with them for a month, forbid yourself from tinkering, and judge them only on “Did I actually use this when I was tired and busy?”
You already got two solid “system” answers from @kakeru and @nachtdromer, so I’ll zoom in on how to choose apps without going in circles.
1. Decide what you actually do all day
Before picking tools, list 5 recurring things:
  • “Capture quick ideas on the go”
  • “Remember boring life admin”
  • “Plan focused work blocks”
  • “Keep long-term info like receipts / medical / contracts”
  • “Coordinate with partner / team”
Now assign one app type per activity:
  • Capture quick ideas → notes app
  • Boring life admin → task app
  • Focus blocks → calendar
  • Long-term info → notes app folders
  • Coordination → shared list or shared calendar
If an app cannot serve one of these roles cleanly, ignore it for now, even if it looks shiny.
2. Choose apps by “friction score,” not features
Take any candidate and test for 3 days:
  • How many taps from phone unlock to “new task / note”?
  • How fast is search on a mediocre connection?
  • Do you want to open it when tired, or do you sigh?
If friction is high, it does not matter how advanced it is.
This is where I slightly disagree with both of them: I don’t care whether it is “small stack” or “single spine” if the friction is high. A slightly fragmented system that is frictionless beats a perfectly unified one that you avoid.
3. Use overlap apps carefully
Some apps are calendar + tasks + notes in one place. That sounds ideal but is often confusing.
If you go this route, treat it like 3 separate tools inside 1 app:
  • Tasks section only for actionable items
  • Notes section only for reference or drafts
  • Calendar section only for time
Turn off features you do not understand yet. Advanced stuff should be opt in, not default.
4. How to know if an app is “too complex” for you
Red flags in the first week:
  • You keep wondering “Where should this go?”
  • You need to watch tutorials to do basic things
  • You spend more time customizing than completing tasks
If this happens, it is not “you being dumb,” it is the app not matching your current load. Switch to something plainer.
5. Competitor mindshare
  • @nachtdromer leans into a classic trio: task app + notes app + calendar with a 30 day commitment. Great if you want clear boundaries.
  • @kakeru focuses on the idea of a single “home base” and using everything in minimal mode. Great if you are already living in email or chat.
Both are valid, but if you feel yourself over-optimizing, you might be better off ignoring systems and just choosing what you open without thinking.
6. When you finally commit
Whatever apps you pick, write down three rules:
  1. All new tasks go into X.
  2. All new reference info goes into Y.
  3. I only reconsider tools on the last day of the month.
Tape those rules on your desk or make it the first line of your main note. The rules matter more than the logo on the app icon.
