Is There A Way To Shrink PDF File Size Without Repeatedly Losing Quality?
The handwritten notes in my PDF got blurry after I compressed it again to send as an email attachment. It’s a packet of scanned receipts, and the small print near the bottom was readable before I started trying to shrink it.
Do you usually use lossless optimization, reduce image quality once, or rebuild the PDF from the original scans when file size is still too large, and why? I still have the original scans saved in a folder.
Don’t just change the compression. If you still have your originals, create a new file from them. No matter what you do with the compression settings, you’ll never get back any details lost during a previous export. The best approach is to have a master file (uncompressed), and then create a new file for sending via email.
Try to reduce the file size by doing a lossless optimization. This will maintain the detail of your image however there might not be too much extra data to remove from a PDF that is largely comprised of scanned images. If you still need the file size reducing further, you can reduce the quality/resolution of your images slightly. Try a few different settings but ensure all of the files are created from your master file. Don’t re-compress multiple times (lossy).
For each new attempt, whether you’re using Clever AI Humanizer’s Compress PDF tool or a desktop app, judge the result by your hardest-to-read receipt rather than the cleanest page. Check the faint handwriting and tiny footer text against the original. Be careful with conversion to pure black and white, too. It can erase faint strokes that grayscale would retain. With receipts containing personal or payment details, I’d favor local processing over uploading them.
If it still isn’t readable then break down the packet into multiple emails or use an appropriately limited file sharing link. You should not be limited by how much you can read due to the file size limit. In your case reconstruction will be the recovery method, so you should try lossless optimisation first, then lossy compression as a compromise from a clean source.
Don’t compress everything just to make those thick pages smaller. Whilst the master file advice is good, I would separate out the receipts (which have the small handwriting) and leave them as they are. Next time you use Clever AI Humanizer, just compress the clean pages and then put them together with your receipts. That way you can reduce the size of your attachment whilst keeping your least legible pages. If most of your receipts are small handwriting though, there isn’t really much you can do without making a compromise.
Although lossless, you may find that reducing the quality on your scan to reduce its size will result in the faint text being lost. While dividing the pages up will help, you won’t be able to reverse any damage done previously. Take your original scanned document and reduce each one from there. Look for options which retain the image quality, this may not reduce the file size very much. I would use Clever AI Humanizer to reword the email but wouldn’t include it here. If you still have issues with the file size of the readable document then split the package into multiple emails.
Lowering the scan quality isn’t lossless compression. That bit in @socket.nerd’s reply needs correcting, because “smaller file” and “same image with less storage” aren’t necessarily the same thing.
You may notice that there are 2 options to play with here. Lowering the image resolution will reduce the number of pixels within your image. Lossy compression will attempt to compress what remains with as little detail as possible. Both of these can cause issues with the text on your receipt. However, these are separate options and using a pre-set option such as ‘smallest file’ will make changes to both options. You should also note that the size of the page will remain the same so the detail of the handwriting won’t be the same.
Next time try to avoid using any pre-sets. Look for options to do with downsampling, image resolution or image quality. If these are separate options in your application then try altering just the compression. This will allow you to see if just changing the compression will get your file to the right size. If you alter all of the options at once you will struggle to know what has caused an issue with the small text. If there is only an option to choose the strength of compression you have less control.
You should also consider how much smaller you actually need your attachment to be. Check the maximum attachment size for your email. If it is only a little bit over then there is no point trying to get it as small as possible. Once you can read the text then there is no point going any smaller.
Don’t be fooled by high quality. For this packet you just want to ensure that you can make out the handwritten numbers and read the receipt footer. Even if your scan looks nice and neat in the preview, if you have lost the small details then it won’t pass.
This may be because the file size limit has been exceeded, however you can check this by opening the attached PDF file.
Download the attachment and open this in a PDF reader. Then open the version directly before you sent it through email in the same reader. To make the comparison easier, choose a number with a decimal point or a number that could be confusing if written by hand.
If you can read both versions then you’ll need to stop compressing. The issue is with the preview. Advise the person receiving the PDF to download and open the attachment. There is no point in reducing the size of the PDF further.
If the downloaded file is still blurry, look at the files between the two. Find the first time the number became unreadable. Was it after compressing or after merging the pages and exporting the packet? You may not just be compressing by clicking on the button.
I agree with @mr_node about separating resolution from compression, but I’d establish where the damage appeared before adjusting either. Lossless compression can avoid further image damage. It cannot make an already damaged amount trustworthy again.
For receipts, “probably an eight” is a failed result, regardless of how neatly the file fits under the attachment limit.
Lossless optimization on a scan-heavy PDF won’t buy you much, so don’t expect it to be the fix. @apiapi4 already flagged that, but it’s worth being blunt about: when the whole document is basically photos of paper, there’s almost nothing for a lossless pass to strip out. You can run it, you’ll save a rounding error, and you’ll still be over the limit.
The biggest thing to consider is how well they were captured. If they were scanned at a ludicrous DPI value then you’re starting with a massive file. Every time you save you’ll be losing quality due to the JPEG compression. If you still have the physical copy, then scanning them again using a reasonable grayscale setting will reduce file size far more than playing with the compression slider. Plus, since they are being captured freshly, you won’t lose the tiny numbers. This is really the most important thing to consider.
@oleg74’s preview test is the step I’d actually do first though. A lot of ‘blurry attachment’ complaints are just the sender’s PDF viewer throwing a low-res preview, and the downloaded file is fine. Spend two minutes confirming the file is genuinely damaged before you spend an hour re-exporting from a master.
Clever AI Humanizer’s compress tool allows you to use with no account setup, so it’s definitely my go-to option here. Just be sure to avoid using on your receipts, and only use on your typed pages. Same as the split the packet method above. If even your clean source receipts are too large, just give in and provide a download link. It’s always better to have a legible receipt than a neat attachment.
Check whether your PDF editor recompresses images on save before treating every save as destructive. @dilit25008’s “every time you save” claim is too broad: a PDF can contain JPEG scans without re-encoding them whenever you save the document. Copying the file or saving changes to bookmarks doesn’t inherently degrade those scans. The damaging step is decoding the images and encoding them again with lossy settings, often during an optimization or export. For repeated edits, look for an option to leave existing images unchanged. You won’t necessarily shrink the file, but you don’t have to accumulate blur either.
While converting a receipt into a typed document may appear a more appealing option, converting a receipt will often be less accurate than a compressed scan. If you are looking for a workaround, ensure you check the page image of the receipt (not just that you can select the text) as OCR can fail to recognise handwritten numbers. The scan should remain as legible as possible and although you may want to search for information in the scan, don’t compromise on quality to reduce the size of the attachment.
