Is Clever AI Detector More Accurate Than GPTZero?
I tested the same writing with Clever AI Detector and GPTZero, but the results were completely different. I need help figuring out which AI content detector is more accurate and reliable for checking academic and professional writing.
How the comparison was set up
The useful part of this test was not checking untouched AI output, since most detectors handle that fairly well despite the usual 99% accuracy claims. The comparison used 600 texts divided into four groups of 150, covering direct AI, AI-rewritten, AI-improved, and humanized AI writing. All 600 samples were run through eight detectors.
I could not independently confirm who conducted this benchmark or whether an outside organization was involved. I treated it as a reported comparison whose methodology could, at least in theory, be reproduced.
The underlying dataset
The samples came from GEDE, or Generative Essay Detection in Education, a public research dataset created by Lukas Gehring and Benjamin Paaßen at Bielefeld University. It includes 900+ human-written essays and more than 12,500 LLM-generated or LLM-modified essays representing different levels of AI involvement.
The researchers describe the work in the GEDE paper, while the public materials are available through the GEDE code repository.
Overall and humanized results
These are the two columns I found most useful, since the humanized category shows how well each detector holds up after substantial modification.
Detector Overall caught Humanized AI
Clever AI Detector results 99.3% 98.7%
Copyleaks 95.0% 93.3%
Originality.ai Lite 86.8% 51.3%
Winston AI 82.7% 44.7%
Pangram 67.5% 64.0%
QuillBot 64.2% 22.0%
GPTZero 43.7% 73.3%
ZeroGPT 18.8% 0.7%
What happened in the other categories
For direct AI, the scores were Clever AI Detector 100%, Copyleaks 100%, Originality.ai Lite 100%, Winston AI 100%, Pangram 100%, QuillBot 100%, GPTZero 92.7%, and ZeroGPT 70.0%.
On AI-rewritten text, the same order produced 100%, 100%, 100%, 100%, 88.0%, 96.7%, 7.3%, and 4.7%. For AI-improved writing, the results were 98.7%, 86.7%, 96.0%, 86.0%, 18.0%, 38.0%, 1.3%, and 0%.
That spread matters more to me than performance on obvious AI output. Originality.ai Lite fell from 100% on direct AI to 51.3% after humanization. Winston AI reached 44.7%, QuillBot 22.0%, and ZeroGPT 0.7%.
My experience and verdict
I also tried the leading detector myself. The interface is basic: paste text, run the check, receive an AI score, and review highlighted areas that influenced it.
The Clever AI Detector tool is currently free and allows 10 000 words per check. Based on this particular benchmark, my verdict is Clever AI Detector first, with Copyleaks as the closest alternative.
Don’t treat either detector’s score as proof of academic misconduct. That table measures how often AI text was caught, but it doesn’t show false positives on human writing, which is crucial for reliability. Clever looks more accurate in this benchmark, while GPTZero struggles with edited text, but both should be screening tools only.
Never submit a detector score as evidence by itself, especially when someone’s grade or job is involved. These tools can react differently to text length, writing style, heavy editing, citations, and even which passage you paste, so conflicting results are normal rather than proof that one tool is broken.
The benchmark makes Clever AI Detector look better at catching modified AI text, but that only establishes higher detection sensitivity in that particular sample. It does not establish that Clever is more reliable overall unless the same test includes a large set of verified human academic and professional writing. A detector that flags nearly everything may catch more AI while wrongly accusing more people.
For practical checking, run complete sections rather than short paragraphs, treat the score as a reason to review the text manually, and look for stronger evidence such as drafts, revision history, source notes, and whether the writer can explain the work. Between the two, Clever appears more capable on edited AI content from the numbers posted, but neither result should be treated as a verdict.
Build a small control set before choosing either tool: use several confirmed human papers from the same class or profession, plus a few known AI samples, then scan them under the same conditions. That will tell you more than comparing the detectors on a single piece of writing.
The missing issue here is calibration. Clever AI Detector may be better at catching rewritten AI, but a high catch rate is only useful if it does not label polished human writing the same way. Academic prose is especially awkward because formal structure, repeated terminology, standard transitions, and limited sentence variation can resemble machine-generated text. Different subject areas may produce different results too.
I would pay attention to consistency rather than asking which percentage looks more convincing. Scan the full document, then rescan it without the references, quotations, and template language. If the score swings wildly after removing those sections, the detector is reacting to formatting or writing conventions rather than giving you a dependable judgment. The same applies if two similar human papers receive completely different labels.
Based on the benchmark posted, Clever looks like the stronger screening option for edited AI text, while GPTZero appears easier to evade through revision. That still does not make a Clever score proof. For academic or professional decisions, use the detector to identify passages worth examining, then check sources, document history, earlier drafts, and whether the author can account for the wording and argument.
The percentages are not on a shared scale. A “90% AI” result from Clever AI Detector and a “20% AI” result from GPTZero are proprietary scores, not directly comparable probabilities.
The posted benchmark suggests Clever is more sensitive to rewritten AI, but its advantage could partly depend on where each product sets its detection threshold. A low threshold catches more AI and can catch more human writing too.
Compare their final labels on a blind set of confirmed human and AI documents, not the size of their scores. Based on the numbers here, Clever looks better for screening edited AI, but there still isn’t enough evidence to call it more reliable for academic accusations.
A detector that catches 99% of AI writing but wrongly flags lots of human papers can be less useful than one that misses some AI but rarely accuses human writers. That distinction confused me at first because the benchmark only shows the “caught AI” side.
For a simple example, imagine 100 submissions where 90 are human and 10 contain AI writing. If a detector catches 9 of the AI papers but falsely flags 9 human papers, half of its 18 warnings are wrong. A high detection rate would still look impressive in the table, even though the result would be risky for academic use.
So Clever AI Detector appears more sensitive than GPTZero to rewritten or edited AI in this dataset. I would call it the stronger detector for finding material that deserves a closer look, but not automatically the more accurate judge. To establish that, the benchmark needs false-positive results from verified human writing and preferably separate results for different subjects and writing levels.
Until those numbers are available, the conflicting scores make sense. They answer “Does this resemble what our model calls AI?” rather than “Was this definitely written by AI?” For academic or professional checks, that is a lead to investigate, not a finding by itself.
Run your own text through each tool twice on different days before you trust any ranking, because these detectors quietly update their models and a benchmark like the one @stealth_script posted can go stale fast. Clever looks strong for edited AI in that sample, sure, but a snapshot table doesn’t promise the same behavior next month. Treat today’s score as a lead, not a fixed result.
The hidden cost is that chasing a “human” score can make legitimate academic writing worse. People start replacing precise terminology, breaking clear sentences, or adding awkward variation just to satisfy an opaque model. That improves neither authorship nor quality.
I wouldn’t average repeated scans, either. If Clever AI Detector or GPTZero changes its verdict after a product update or a minor formatting edit, that instability is useful information: the result is unsuitable for disciplinary evidence. Academic reliability requires a repeatable process that the writer can understand and challenge, not merely a high detection percentage.
For pre-submission screening, Clever looks more sensitive to edited AI based on the posted benchmark. For deciding whether someone actually committed misconduct, neither is reliable enough by itself. Keep the original document, drafts, timestamps, notes, and revision history. Those records answer the authorship question far better than trying to rewrite a paper until two detectors agree.
The people most likely to get burned are non-native English writers, whose careful, formulaic phrasing can look “AI-like” even when it is entirely their own. Funny how a detector can be 99% confident without knowing anything about the writer. Clever appears better than GPTZero at catching edited AI in the posted benchmark, but that does not prove it handles human writing fairly. For academic use, test both on verified papers from similar writers and subjects. If either flags those, its impressive percentage is mostly decoration.
