I just switched from an iPhone to an Android phone and now I can’t join my family’s FaceTime calls anymore. They all use FaceTime on their iPhones and Macs, and I don’t want to miss our weekly video chats. Is there any workaround, app, or web option that lets an Android user join or start FaceTime-like calls with people who are still on Apple devices? Looking for clear, step-by-step advice that actually works on current Android versions.
Short version. You cannot run FaceTime as an app on Android, but you can still join FaceTime calls if someone with an iPhone or Mac sends you a special link.
Here is how your family needs to set it up so you can join from Android:
On their iPhone or iPad
• Open FaceTime.
• Tap “Create Link”.
• Choose how to share it, like Messages, WhatsApp, email, etc.
• Send that link to you. -
On their Mac
• Open FaceTime.
• Click “Create Link”.
• Name the call if they want.
• Share the link with you. -
On your Android phone
• Tap the link they sent.
• It opens in Chrome or another browser.
• Type your name when asked.
• Tap “Continue” or “Join”.
• Give the browser permission to use your camera and mic.
• Wait for them to approve you in the call.
A few catches and tips:
• You cannot start FaceTime calls from Android. Only iPhone, iPad, or Mac users start them.
• You need at least Android 8 and a modern browser. Chrome or Edge works better than random browsers.
• If the link does nothing, tell them to resend it from FaceTime, not from some old text thread.
• If you see video but no audio, check:
– Phone volume.
– Browser site permissions for mic and camera.
– Try switching to Wi‑Fi if mobile data lags.
If you want something closer to how it worked on iPhone, you have two paths:
Option A: Keep FaceTime via links
Pros:
• Stays in their normal Apple setup.
• You only need a link and a browser.
• You depend on them to start the call each time.
• No FaceTime app for you, so a bit clunky.
Option B: Get them to move the weekly call to a cross‑platform app
Stuff that works well across iOS, Android, Mac, Windows:
• WhatsApp
– Video calls work on iPhone and Android.
– Group video calls up to 32 people.
– End to end encrypted.
– Uses around 4 to 6 MB per minute of video on average, lower than some rivals.
• Google Meet
– Free with Google accounts.
– Browser based, no install on computers needed.
– Runs on iOS and Android apps.
– Stable on weak connections if you lower resolution.
• Zoom
– Free plan gives 40‑minute group calls.
– Easy links.
– Works on everything, but needs the app or desktop client.
• Messenger / Instagram video
– Works if your family already uses Facebook or IG.
– Quality is fine, group calls supported.
What tends to work best for mixed Apple + Android families:
- Keep using FaceTime for random quick calls between the Apple folks.
- Pick one cross‑platform app for weekly family chats.
- Make a repeating group in that app so you do not juggle links.
If your family really wants to stay on FaceTime only, ask one of them to:
• Create a FaceTime link once.
• Save it in Notes or a pinned chat.
• Reuse that same link for the weekly call.
FaceTime links often keep working for repeat calls unless the owner deletes them. That turns it into something similar to a standing meeting room so you just tap the same link each week.
So your steps now:
- Ask them to update iOS or macOS to the latest version if they have not.
- Tell them “Create FaceTime link and send it to me” before the call.
- Open the link in Chrome on Android, give permissions, join.
- If this feels annoying after a few weeks, vote for WhatsApp or Meet for the weekly call.
Short version: you’re never getting a real FaceTime app on Android, but you’re not totally locked out either.
@techchizkid already covered the official “FaceTime link in your browser” method, so I won’t rehash the same click‑this‑tap‑that list. I’ll hit what they missed and what actually matters long‑term.
1. Make FaceTime-from-Android slightly less annoying
FaceTime links in Chrome are fine, but clunky. You can make it feel a bit more “app‑like”:
a) Add the FaceTime meeting link to your home screen
If your family uses the same reusable FaceTime link each week:
- Open the link in Chrome on Android.
- Tap the three dots in the top‑right.
- Choose “Add to Home screen.”
- Rename it like “Family FT Call.”
Now it’s one tap each week instead of digging through texts. It still opens in the browser, but it feels closer to an app.
b) Use a better browser setup
FaceTime-in-browser hates weird adblockers or ultra‑locked‑down privacy modes. If you get black screens, frozen video, or “waiting to connect” forever:
- Try Chrome or Edge with their default settings.
- Turn off aggressive adblockers or “block all third‑party cookies” just for that site.
- Use Wi‑Fi if your mobile data is spotty; FaceTime is picky about unstable upload speeds.
2. Fix the two most common “why isn’t this working” issues
People blame Android, but usually it’s one of these:
a) Old Apple software on their side
The Apple people need relatively recent iOS / macOS. If someone is sitting on ancient iOS:
- They might not see the “Create Link” option at all.
- Or the link behaves weirdly in browsers.
If the link never loads or errors out constantly, tell them to check for system updates. No update, no clean FaceTime‑link experience.
b) Camera / mic issues on Android
You join, they see your name, but no video/audio from you:
- Check Android Settings → Apps → your browser → Permissions → make sure Camera & Microphone are allowed.
- Inside the call, some browsers have a tiny camera icon in the address bar; tap it to confirm “Allow.”
- Plug in wired earbuds or use Bluetooth if echo or feedback is awful.
3. Decide if you actually want to keep this setup
Here’s where I slightly disagree with the “just keep FaceTime via links” idea. It works, but for a weekly scheduled call it’s honestly not the best option:
Why FaceTime‑link is kinda meh for your use case:
- You can never start the call yourself. You’re always waiting on someone with an Apple device to kick things off.
- If that one person is late or forgets, the whole call is stuck.
- Any small change (new phone, new Apple user, deleted link) means confusion all over again.
For a recurring “every Sunday at 7” family call, a neutral app is usually smoother.
4. If you try convincing them to switch, aim smart
Instead of throwing 5 different apps at your family, pick one and remove friction:
- Easiest for most families if they already use it to text.
- Works on iOS, Android, and has a desktop app.
- You can create a family group chat and just hit the video icon at call time.
Google Meet
- Great if people already use Gmail or Google Calendar.
- You can set up a recurring calendar event with the same link every week.
- They click, you click, done.
Zoom
- Fine if your family is already familiar from work or school.
- Slightly annoying sign‑in / app install for the less techy relatives.
If your family is stubbornly Apple‑only in their brains, pitch it this way:
“You all can still use FaceTime for day‑to‑day, but let’s make the weekly family thing something everyone can start and join without hassle.”
5. Minimal‑effort plan that actually works
If you don’t want to fight that battle yet, here’s a simple hybrid:
- Ask one Apple person to create one FaceTime link specifically for “Family weekly call.”
- Have them pin that message in your existing group chat or put it in a shared note.
- On your Android, open it once in Chrome and add it to your home screen.
- Each week, at call time, you just tap that icon and wait to be let in.
If that routine starts to annoy people in a month or two, that’s your perfect moment to suggest WhatsApp / Meet as a permanent home.
So: no native FaceTime app, browser FaceTime is a workaround, home‑screen shortcut and a reusable link keep it tolerable, and a cross‑platform app is the real long‑term fix if you can talk the family into it.
