How To Turn Off Ai On Pinterest
Pinterest started showing AI features and recommendations in my feed, and I can’t figure out how to disable them. I’ve looked through the app settings and account options but haven’t found a clear way to turn off AI on Pinterest. I need help finding the right setting or workaround so I can get back to a more normal Pinterest experience.
Pinterest does not give you one clean switch for all AI stuff. Annoying, yep.
What you can do:
  1. Turn off personalized stuff
    Go to Settings, Privacy and data, then ad personalization or personalization settings. Turn off anything tied to recommendations, activity use, and off-Pinterest data.
  2. Hide AI pins one by one
    On posts you do not want, tap the three dots, then choose Hide Pin, Not relevant, or similar. This trains your feed over time. Slow, but it helps a bit.
  3. Reset your recommendations
    Go to Settings, tune your home feed if the option shows up. Remove topics, boards, or recent activity pushing the AI junk.
  4. Clear search history
    Delete recent searches. Pinterest uses those a lot.
  5. Switch off email and push suggestions
    Settings, Notifications. Turn off reccomendations and trend alerts.
  6. Use the web version
    Sometimes the desktop site shows fewer forced prompts than the app. Not always, but worth a shot.
Short version, you cannot fully disable AI on Pinterest right now. You only get partial control. Pinterest keeps mixing it into search, feed ranking, and suggestions. Kinda dumb, but thats where it stands.
You probly can’t fully turn it off, but there’s one angle @byteguru didn’t really hit: your account type and region matter. Some AI labels, generated search helpers, and shopping suggestions are baked into experiments Pinterest rolls out server-side, so two people can have totally diff options in settings. Super annoying.
A couple other things to try:
  • If you have a business account, switch back to personal. Business profiles usually get more aggressive recommendation junk, trend prompts, and automated tools.
  • Turn off “auto-enhance” style creation tools when making Pins. That won’t fix the feed, but it cuts down AI features in the posting flow.
  • Log out and use Pinterest without being signed in for a bit. I know, not ideal, but the feed can be way less “trained” on your behavior.
  • Use an older app version only if you’re on Android and know what you’re doing. Sometimes newer AI widgets get pushed hardest in recent builds. Not a forever fix tho.
  • If specific AI generated Pins are the issue, check whether “AI modified” labels can be filtered in search. It’s limited, but sometimes works better than the home feed.
I’d actually disagree a little with the “desktop is better” thing. For me the web version was just as stuffed with suggested crap, just laid out diff. Pinterest wants that engagement either way.
So yeah, no master off switch. More like 12 tiny levers and half of them dont do much.
There still is not a true “turn off AI on Pinterest” switch, but I’d add a different fix path than @byteguru’s angle.
What actually helps most is retraining the feed hard:
  1. Long-press AI-ish Pins and hit Hide or Not relevant every single time.
  2. Open Settings, then tune down personalization where possible, especially ad personalization and inferred interests.
  3. Clear recent search history and board activity tied to topics that trigger AI content.
  4. Unfollow broad trend-heavy boards. Follow only narrow niche topics for a while.
  5. Create a fresh board set around exactly what you want. Pinterest often rebuilds recommendations from that faster than people expect.
I slightly disagree with the “older app version” idea. Usually not worth the hassle, and server-side experiments can ignore that anyway.
Pros for ‘’: can improve readability if you’re organizing troubleshooting steps or summaries.
Cons for ‘’: not really useful unless you’re turning this into a guide or blog post.
