I recently switched to a Mac and can’t figure out the fastest way to open the emoji picker while typing in apps like Messages, Mail, or browsers. I’m used to a simple shortcut on Windows, but on macOS I’m not sure if there’s a universal keyboard shortcut or a menu option. Can someone explain the easiest, system-wide way to open emojis on a Mac, and if there are any useful tips or settings to make emoji access quicker?
Fastest ways to open emojis on Mac while typing:
Main shortcut
Use this almost everywhere:
Control + Command + Space
Press it while your cursor is in a text box.
A small emoji / symbol panel pops up.
Type to search, hit Enter to insert. -
Make the panel stay open
If you want a bigger panel that stays on screen:
Press Control + Command + Space.
In the little window, click the icon in the top right corner.
It turns into the “Character Viewer” and floats.
You can leave it open and click emojis as you type. -
Alternative access
In many apps you also have:
Menu bar > Edit > Emoji & Symbols
Same thing, but the shortcut is faster. -
Trackpad emoji button
On some MacBook models, when you tap the globe / fn key, it opens the emoji picker.
Check this:
System Settings > Keyboard
Look for “Press fn key to” or “Globe key”
Set it to “Show Emoji & Symbols”. -
Touch Bar (if you have one)
In typing apps, emojis often show on the Touch Bar.
You tap the smiley icon, pick one, it inserts instantly.
Not all apps use it, but Messages, Mail, and Safari usually do. -
Works in most places
Control + Command + Space works in:
Messages
Mail
Safari, Chrome, Firefox
Notes
Pages, Word
Slack, Discord, etc.
If it looks like a text field, the shortcut usually works.
Once you get used to it, it feels similar in speed to Windows Win + period.
Muscle memory takes a few days, then you stop thinking about it.
The Windows → Mac emoji transition is weirdly annoying, yeah.
@codecrafter already covered the “proper” shortcuts, but a few extra angles that might help you get something faster or more natural:
Remap something to feel like Win + .
If you really miss that shortcut, you can fake it with a tool like Karabiner-Elements:- Map something like
Option + .orCommand + .to triggerControl + Command + Space. - That way your muscle memory is closer to Windows and you’re not hunting for the Control key combo all the time.
Personally I find this way quicker than remembering the default.
Use text replacements for your top emojis
macOS text replacement is surprisingly decent:- System Settings → Keyboard → Text Replacements
- Add things like
:shrug→ ¯_(ツ)_/¯ or:spark→
These expand in Messages, Mail, browsers, etc. No picker needed for the ones you spam constantly.
Let apps handle emojis for you
Some apps are smoother than the system picker:- Slack / Discord have
:+ name (:smile) style emoji search. - You can lean on that instead of using the macOS viewer at all in those places.
On Mac I honestly use colon-codes way more than the emoji palette.
Turn on the old-school menu icon
If you’re using emojis a lot while writing longer stuff, having one-click access helps:- Open the emoji/symbol viewer once.
- In the top-left of that window, click the little gear / menu icon.
- Enable “Add to menu bar” (or similar wording, depends on macOS version).
That puts a tiny icon in your menu bar so you can open the full Character Viewer with 1 click. Not as sexy as a shortcut, but handy if you forget key combos.
Slight disagreement with relying only on Control + Command + Space
It’s solid, but if you’re mid-sentence and typing fast, reaching for three keys every time kinda sucks. For speed:- Use a remap for the shortcut.
- Use text replacements for favorites.
- Use app-specific emoji search (like
:shortcuts).
Combo of those is almost always faster than just slamming the system picker all the time.
TL;DR:
System shortcut is fine, but if you want “Windows-fast,” remap a simpler hotkey and mix in text replacements and colon-style emoji codes. After a week your hands stop complaining.
If you want “Windows-style” speed for emojis on Mac, I’d actually lean less on extra tools and more on reshaping how you use the built‑ins.
1. Commit one shortcut and stop hunting
Control + Command + Space is the default. I’d stick with it rather than over‑remapping like @codecrafter suggested. Muscle memory on one combo is usually faster long term than a bunch of clever remaps, especially if you move between different Macs or user accounts.
2. Use the inline search properly
When the emoji picker pops up, you can instantly type a word:
- Type “smile,” “thumbs,” “fire,” “party,” etc.
- Hit Enter to insert.
The trick is to treat it like Spotlight: shortcut, 2–3 letters, Enter. No trackpad, no scrolling. This feels close to Win + . speed once you stop mousing around.
3. Rely on predictive emoji in some apps
In Messages, Mail and a bunch of third‑party apps, macOS will suggest emojis as you type a word. For example:
- Type “happy” and look at the suggestion bar.
Tap Fn or use arrow keys to accept. It is not as consistent as Windows, but in common apps it cuts down on needing the picker at all.
4. Use the fn key toggle where possible
On newer Macs, fn can open the emoji selector while in some contexts. Check:
System Settings → Keyboard → Keyboard Shortcuts → Keyboard
See what fn is bound to. If it can be set to emoji & symbols, that gives you a single key access in supported fields. That can feel even faster than Win + . once you get used to it.
5. Pros & cons of depending on the built‑in “How To Open Emojis On Mac” approach
- Works system‑wide with no extra apps.
- Stable across OS updates.
- Keyboard‑only flow is actually quick once you rely on search.
- Cleaner than stacking Karabiner setups you have to maintain.
- Three‑key shortcut is awkward for some hand positions.
- Predictive emoji is inconsistent across different apps.
- The picker UI is more cramped than the Windows one, especially on small screens.
6. Quick contrast with what @codecrafter suggested
They lean harder into remapping keys and text replacements. Those are valid if you live on a single machine and have a few favorite emojis. I just think for someone freshly moved from Windows, mastering the native shortcut + search + predictive suggestions first gives you a more portable habit that works on any Mac you touch.
If you still hate it after a week of really using Control + Command + Space with inline search, then add remaps and replacements on top instead of starting there.
