How can I install mods on Bonelab Quest 2 without using a PC?
I recently got into playing Bonelab on my Quest 2 and I’ve heard a lot about cool mods that can enhance the game experience. Unfortunately, I don’t have access to a PC at the moment. Is there any way to install mods directly on the Quest 2? If so, could someone guide me through the process or point me towards a useful resource? Really appreciate any help you can provide!
If you’re looking to install mods on Bonelab for the Quest 2 without a PC, you’re in luck. There are a few ways to get this done right from your headset.
  1. SideQuest mobile app – You can use the SideQuest mobile app to browse and install mods directly from your phone. Here’s a quick rundown:
    a. Download and install the SideQuest mobile app from the Google Play Store or Apple App Store.
    b. Connect your Quest 2 to your phone using a USB-C cable or via Wi-Fi setup.
    c. Enable developer mode on your Quest 2 through the Oculus app on your phone if you haven’t already.
    d. Open the SideQuest app, navigate to the “Games & Apps” section, search for Bonelab mods, and hit that install button.
    This method is super convenient and doesn’t require a PC.
  2. Using Built-in Browser – Surprisingly, your Quest 2’s built-in browser can be of great use here.
    a. Launch the browser and navigate to a modding site that supports Bonelab.
    b. Download the mods to your headset.
    c. Using a file manager app on your Quest 2, you can then navigate to the downloaded mod files and move them to the appropriate game folder.
    This is a bit of a workaround but does the job.
  3. Quest App Launcher – Another option is using a file management app like Quest App Launcher, which can be installed directly on your headset.
    a. Download and launch the Quest App Launcher.
    b. Install the mods through the app after downloading them via the browser.
    c. Navigate to /sdcard/ directory on your Quest 2 with the Application and locate the Bonelab data folder to paste the mods.
These methods should get you started without needing a PC. Just make sure you follow the instructions for each mod carefully because not all mods might be fully optimized for direct installation from the Quest 2. Happy modding!
Surprised no one’s mentioned the joys of diving into the world of Virtual Desktop or Air Link to take care of modding your Bonelab on Quest 2 without a PC! It’s not as direct, but here’s another way you can get creative:
You could technically use Virtual Desktop or Oculus Air Link to wirelessly connect your Quest 2 to a PC on the same network, even if it’s borrowed from a friend or family member. This way, you can utilize all those awesome PC-based modding tools and still get the job done.
Also, let’s talk about alternative file management methods on Quest 2 itself. Using an APK installer for file management applications directly on your Quest 2 can be a game-changer too!
  1. Install a robust file manager directly on the Quest 2 – Something like XFile Explorer. If you do some Googling, you’ll find many APKs for powerful file managers.
  2. Move mod files appropriately – Use this file manager to handle all your mod files efficiently, like a pro.
One thing though, avoid relying solely on wireless connections for large mod files. Stability can be inconsistent and you don’t wanna face broken installations.
Using cloud storage is underrated too. Try:
  1. Upload mod files to Google Drive or Dropbox from your phone.
  2. Access them via the Quest’s built-in browser. This way, even if one file fails to download correctly, you won’t lose your progress; just retry.
Sometimes getting creative with the tools available can make all the difference! And yeah, remember to enjoy the joyous chaos!
Hope that’s helpful, and let’s keep sharing those modding experiences.
Actually, just wanna chime in here – there’s another neat trick you can try: using cloud gaming services for modding, especially if you don’t have access to a PC. Although it’s unconventional, it can be a lifesaver in certain situations.
Cloud Gaming Approach: Platforms like Shadow or Google Stadia can offer you a virtual PC environment to work with. Here’s the breakdown:
  1. Sign up for a cloud gaming service like Shadow or Stadia.
  2. Access the virtual desktop environment; essentially, you get a full Windows experience.
  3. Download and install modding tools and necessary mods as you would on a physical PC.
  4. Transfer mods to your Quest 2 using the methods @caminantenocturno and @waldgeist suggested, particularly via Google Drive or Dropbox.
Pros:
  • Great for those without access to a physical PC.
  • Offers a PC-like experience remotely.
  • Can be a bit laggy depending on your internet connection.
  • Subscription fees for cloud gaming services.
For those who find methods like the SideQuest mobile app and built-in browser a bit tricky or limited, cloud gaming can be a robust alternative.
Oh, and a crucial bit often overlooked – ensure your internet connection is stable and fast when using these methods, especially for downloading files. Performance can tank if your network isn’t up to snuff.
Lastly, always be wary of where you’re downloading mods from to avoid corrupted files or malware. Stick to reputable modding sites within the VR community.
Hope this gives you that extra edge in getting your Bonelab all modded out! Happy modding and game on!
Also, @waldgeist and @caminantenocturno had some stellar suggestions. If you want to bypass some potential wireless transfer hiccups, they really hit the nail on the head with their points. No one approach will fit all, so combine a bit from everywhere for best results.
Use an Android phone with USB‑C instead of cloud PCs.
  1. Install CX File Explorer from the Play Store.
  2. Download Bonelab mods from a trusted site in the phone browser.
  3. Connect Quest 2 to the phone with a USB‑C OTG cable.
  4. On Quest, allow file access.
  5. In CX, copy the mod files into
    Android/data/com.StressLevelZero.BONELAB/files/Mods
  6. Reboot the headset and load Bonelab.
This keeps everything on mobile, no desktop or cloud service.
