I just tried a new app and want to write a short, honest review but I’m not sure what details to focus on so it’s actually helpful. I’d like advice on what key points to mention, like usability, features, bugs, and overall value, so my review is useful for other users and stands out in app store search results.
Here is an easy structure you can follow so your review helps people and stays honest. You can hit all this in 3 to 6 short sentences.
Start with what the app is for
Example: “Used this for tracking my workouts for a week on Android.” -
Talk about ease of use
• How fast did you understand it
• Was onboarding clear
Example: “Setup took 3 minutes, layout is simple, but some icons confused me at first.” -
Mention key features you tried
Focus on what you actually used.
Example: “I used the workout plans and progress charts. Both worked fine. The social feed felt cluttered so I ignored it.” -
Mention bugs or issues
Be specific.
• Crashes
• Lag
• Wrong data
Example: “The app froze twice when I opened the stats tab on older workouts.”
Avoid vague stuff like “buggy” with no details. -
Talk performance and speed
Example: “Loads in about 2 seconds on my phone. Sync to cloud took longer on mobile data.” -
Comment on design and UX
Short and direct.
Example: “Clean look, big buttons. Text on some screens is too small.” -
Price and value
• Free vs paid
• Subscriptions
Example: “Free version works for basic tracking. Subscription feels expensive for what you get.” -
Close with who it is for
Example: “Good for beginners who want simple tracking. Power users might want more control over stats.”
Template you can copy and tweak:
“Used this app on [phone type] for [time period] to [main purpose]. Setup was [easy/hard] and the interface is [clear/confusing]. I mostly used [features], they worked [how they worked]. Ran into [specific bugs or issues] while doing [what you were doing]. Performance was [fast/slow] and battery use was [light/heavy]. The [free/paid] version gives you [value level]. Overall, I’d recommend it to [type of user], but if you need [advanced thing], you might want something else.”
Write it like you talk. A few typos are fine, no one on the store is grading your english.
Honestly, don’t overthink it. People just want to know “should I install this or not?” in like 20 seconds.
I like what @yozora laid out, but if you try to hit every point they listed, your review can start reading like a school assignment. For a short, helpful review, I’d focus on 4 things and keep each one to a quick phrase:
What you did with it
One line, super clear.- “Used it for planning a weekend trip with friends.”
- “Tried it for 3 days to track my calories.”
What felt good vs what felt annoying
Don’t list everything, just 1–2 highs and 1–2 lows.- “Nice clean layout, easy to find what I need.”
- “Too many popups and nagging to upgrade.”
Skip generic stuff like “great app” or “terrible app” with no reason.
One concrete problem (if any)
Instead of hunting for every bug, just mention the one thing that would matter to a new user.- “Notifications sometimes arrive late by 10–15 minutes.”
- “Crashes whenever I try to upload more than 5 photos.”
If it ran perfectly, literally say “Didn’t hit any bugs so far on [phone model].”
Your bottom line
Think: “Who should bother installing this?”- “Good if you want something simple and don’t care about advanced stats.”
- “Probably not worth it unless you really need [specific feature].”
A tiny template you can almost fill in like mad libs:
“I used this on [phone] for [how long] to [main thing you did]. The good: [1–2 things]. The bad: [1–2 things]. I had [no / 1 clear] issue: [what happened, when]. Overall, I’d say it’s [score / quick verdict] and best for [type of user].”
Example with actual content:
“Used this on iPhone 13 for a week to track my sleep. The graphs are clear and it’s easy to check last night at a glance. The bad: too many ads and the ‘premium’ popup is constant. Had one issue where it froze on the stats screen twice. Overall feels solid for casual tracking, but if you’re really into detailed data it’s kinda basic.”
That’s it. 4–6 sentences, specific but not a novel, a couple flaws, a couple strengths. If a stranger can read your review and instantly know “this sounds like me” or “nope, not for me,” you nailed it.
Skip the complicated frameworks for a second and think like someone scrolling reviews on the toilet. They skim. So write for skimmers.
What I’d do is build your review around 2 core questions:
- “Would I open this app tomorrow if I didn’t have to?”
- “What would make me delete it?”
Answer those and you’re already more helpful than 90% of “Nice app” reviews.
Instead of repeating what @reveurdenuit and @yozora already broke down so well, try this alternate angle that focuses on feel and friction rather than full-on feature checklists.
1. Describe the feel in one sharp line
Forget “usability” as a formal idea. Just say how it felt to use:
- “Feels snappy and light, like texting, not like filling a form.”
- “Feels slow and clunky, too many steps for simple things.”
This instantly tells people more than “good UX.”
You can plug this right after you name what the app does:
“Tried this budget app for a week. Feels quick for daily checks but clumsy for adding lots of expenses.”
2. Describe the friction
Instead of listing every feature, focus on where the app fights you:
- Too many taps for common tasks
- Constant upsell / ads
- Stuff hidden behind weird menus
- Confusing wording
Example:
“Biggest friction: adding a new task takes 4 taps and a scroll. Doing that 20 times a day gets old fast.”
That “one friction point” is often more useful than a long feature tour.
3. Anchor it to your routine
This is what @reveurdenuit and @yozora only touch indirectly. Tell people when and how often you used it. It changes everything.
- “Only useful for me in the morning to plan the day.”
- “I ended up opening it 5–6 times a day without thinking.”
- “After 3 days I forgot it existed.”
Example:
“Used it 2–3 times a day during work breaks, mostly to log tasks quickly. On weekends I didn’t bother opening it.”
Readers can instantly map that to their own habits.
4. Give a decision sentence instead of a score
Star ratings are already there. Use your text to say what those stars mean.
Good formats:
- “I’m keeping it installed for now, but I’ll delete it if doesn’t improve.”
- “I deleted it after [time] because [clear reason].”
- “I’m paying for it and I don’t feel ripped off / I kinda do.”
Example:
“I’m keeping it for simple daily notes, but I’d drop it if I find something faster with fewer popups.”
That tells more than “4/5, pretty good.”
5. A tiny plug‑and‑play template
Not repeating their templates, here’s a leaner one that leans on feel + friction:
“Used this on [phone] for [time] mainly for [one main use]. It feels [fast/slow/simple/overwhelming] in daily use. Biggest friction is [one thing that annoys you most]. [Optional: Any crash / bug in one short line]. I’m [keeping/deleting] it because [decision reason], so it’s best for people who [who should try it].”
That is enough. Honest, specific, not a mini essay.
About comparing & “competitors” in reviews
You do not have to name actual app competitors, but you can reference other experiences:
- “Compared to most note apps I’ve tried, this one is cleaner but more limited.”
- “Feels like a stripped‑down version of a typical project management tool.”
If you were reviewing something like a task manager, you might say:
- Very quick to jot down tasks
- Clean interface with readable fonts
- Light on battery and runs smoothly
- Repetitive upgrade prompts break the flow
- Lacks deeper features like smart lists or tags
- Occasional freezes when switching between large lists
Users reading that get a snapshot without you writing a full breakdown like @reveurdenuit or walking through every angle like @yozora.
Bottom line:
Write how you talk, anchor it to your daily routine, name one thing you liked, one thing that annoyed you, and state whether you’re keeping or deleting it. That is a short, honest, actually useful review.
