Can I Recover Files From A Thumb Drive After Deleting Photos?
I accidentally deleted photos from my thumb drive and emptied them before realizing they were the only copies. The drive has family pictures I really need back, and I’m afraid using it more could overwrite the files. Is there a safe way to recover deleted photos from a USB flash drive?
If this were my USB stick, I’d start with recovery software, as long as the drive still behaves like a normal drive. Different story if it keeps dropping off, shows 0 bytes, never mounts, looks dead, or gets hot for no reason. At that point I’d stop messing with it. For the usual 'I deleted stuff and now I need it back' mess, software is the first thing I’d try before turning it into an expensive lab job.
The first move is boring but important, stop writing anything to the USB right now. No copying files onto it. No formatting. No cleanup passes. On flash drives, deleted files usually skip the normal Recycle Bin path. The system marks the space as available, and your old data sits there until new data lands on top of it. I’ve seen people lose recoverable files by saving one random video to the same stick five minutes later. Bad move.
Before you scan, I’d do a fast manual check. A lot of 'deleted' files turn out to be hidden, moved, or copied somewhere else earlier.
  1. Show hidden files on the USB and look again.
  2. Check folders like $RECYCLE.BIN, RECYCLER, RECYCLED, or .Trashes if the drive was plugged into a Mac at some point.
  3. Look through your computer’s Desktop, Downloads, Documents, and any folder where you tend to dump stuff when you’re in a hurry.
  4. Check backups and sync folders, OneDrive, Google Drive, Dropbox, File History, whatever you use.
If none of that turns up anything, then yeah, I’d move on to a recovery app.
Most of these tools work in roughly the same way, even if the menus and labels are all over the place:
  1. Install the software on your computer, not on the USB stick.
  2. Connect the USB and pick it inside the recovery tool.
  3. Run a deleted file or lost file scan.
  4. Let the scan finish. Don’t stop early if the files matter.
  5. Use filters if available, file type, name, date, size.
  6. Preview files when the app supports it.
  7. Select what you want back.
  8. Save recovered files to your computer or a different drive, never back onto the same USB.
I’m repeating the last part because people miss it. Recovering data back to the same stick is how you overwrite the rest of what you were trying to save. I did this once years ago. Didn’t do it twice.
Stuff I’d look at first:
  1. Disk Drill. This is the one I’d test first for a normal deleted-files case. The layout is easy to follow, it handles FAT32, exFAT, and NTFS, and the preview tool helps a lot. If a photo or document opens in preview, I usually take that as a decent sign the recovery will be clean. I’ve also had better luck with it when the drive had some file system mess, not only plain deletion.
  2. PhotoRec. Ugly, free, and stubborn in a good way. I keep it around because it digs up files when other tools come back half-empty, especially if the file system is damaged. The tradeoff is rough. Filenames and folder structure often come back wrecked, so you end up sorting a mountain of files by hand. Good emergency option. Not fun.
  3. Data Rescue. I’ve seen it do solid work, though I never liked moving around its interface. If the first scan misses things, this is one I’d use for a second pass. Sometimes a second tool sees stuff the first one glossed over.
  4. Recuva. Old, Windows-only, still useful for simple jobs. If you deleted some docs, JPGs, PDFs, or other common file types from a basic USB setup, it’s still worth a shot. I wouldn’t lean on it first for weird cases or newer formats, but for plain file deletion it still gets mentioned for a reason.
One thing I would not run at the start is CHKDSK, or any repair command in the same family. Those tools are for fixing file system issues. They are not undelete tools. I’ve watched repair commands make recovery uglier by changing directory data before the important files were copied out. My order is simple, recover first, repair later.
So if your USB still shows up normally, I’d scan it with Disk Drill first, pull the important files onto another drive, and deal with the USB itself after that. If the drive feels unstable in a physical way, random disconnects, heat, weird sounds from an adapter, anything like that, I’d stop and hand it to a recovery shop instead of poking at it until it gets worse.
Yes, if the thumb drive still mounts and shows the right size, recovery odds are often decent. Main thing is stop using it now. Every new write trims your chances.
I agree with most of what @mikeappsreviewer said, but I’d add one step before scanning. Make an image of the USB first if you have space on your PC. A sector copy gives you one safe source to scan multiple times. If the stick starts glitching later, you still have the image. On Linux or macOS, dd or ddrescue works. On Windows, USB Image Tool is easy enough.
A few things people miss:
  1. Check the photo app on your phone or PC import history. Old imports often left copies behind.
  2. Look for JPG, JPEG, PNG, HEIC, MOV in Windows Search across the whole computer.
  3. If the photos came from a camera, check the camera card too. People forget this allll the time.
For software, Disk Drill is a solid pick for deleted photos on USB drives because previews save time and help confirm file health before recovery. If previews look broken, don’t panic. Try a deep scan or a second tool after imaging the drive.
One thing I slightly disagree on, Recuva is fine, but on flash media I’ve seen it miss HEICs and newer phone stuff more often than I like. Not usless, just older in feel.
Also, skip quick format prompts, error repair prompts, and ‘scan and fix.’ Those tools love making a mess.
If you want a walkthrough, this flash drive file recovery video guide on Facebook covers the process in plain steps.
Yeah, you can sometimes recover deleted photos from a thumb drive, but the window closes fast. Since you already know not to use the USB anymore, that part is covered. I’d add one thing that @yozora only touched on briefly: if the pics are really irreplaceable, don’t keep plugging the stick in over and over to “see if they’re still there.” Flash drives can go from mostly fine to weirdly unreadable real quick.
I slightly disagree with @mikeappsreviewer on one point though: I would not spend too much time doing manual folder spelunking if you know you deleted them. A quick check, sure. But after that, move straight to recovery before Windows decides to get cute with background writes or indexing.
What I’d do:
  • Plug it in once
  • If it mounts normally, recover from it ASAP
  • Better yet, make an image first if you can
  • Recover files to your computer, not back to the USB
  • Prioritize JPG, PNG, HEIC, MOV, MP4 before anything else
For actual tools, Disk Drill is a solid choice here because it’s easy to sort photos by type and preview what’s actually recoverable. That matters a lot when you’re trying to save family pictures instead of digging through 8,000 mystery files. If Disk Drill finds previews that open correctly, that’s a very decent sign. If it doesn’t, try another tool after working from an image, not the original stick.
Also, tiny reality check: if this thumb drive is exFAT or was used a lot after deletion, recovery may be partial. Some files may come back corrupted or without names. That sucks, but partial recovery is better than none.
If you want more opinions on tools, this thread on best flash drive recovery software for deleted USB files is worth skimming too.
Do not format it, do not run Scan and Fix, and def dont save anything new onto it.
One angle I think @yozora, @jeff, and @mikeappsreviewer only lightly touched: deleted photos are often still recoverable, but flash drives can silently return bad reads before they fully fail. So before chasing every recovery app, copy a few non-important files from the USB to see whether reads are stable. If copies stall, CRC error out, or the drive disconnects, stop and consider a pro lab.
I slightly disagree with the “scan everything immediately” mindset. If these are priceless family photos, first ask: were they ever viewed on this PC? Windows thumbnail cache, photo library apps, chat uploads, email attachments, and old photo editors sometimes leave usable copies or exports behind.
As for software, Disk Drill is a reasonable pick.
  • Easy previews for JPG/PNG/HEIC
  • Good file-type filtering
  • Friendly interface for non-tech users
  • Deep scans can return lots of clutter
  • File names/folders may not survive
  • Paid limits can be annoying depending on version
If Disk Drill finds clean previews, that’s promising. If previews are broken, don’t assume total loss. Thumbnail-only recovery is still better than nothing for family shots. Also check whether the photos were ever printed through a store app or social app backup. Weird source, but it saves people more often than you’d think.
