Can I recover data from a WD external hard drive after formatting?
I accidentally formatted my WD external hard drive and lost important photos, work files, and personal documents. The drive was working fine before, and I really need help figuring out if there’s a safe way to recover the data without making things worse. Looking for advice on WD external hard drive data recovery after accidental format.
I’ve dealt with a few broken WD My Passport drives, and yeah, it sucks every time. Most of mine were fine for years, so I never treated them like fragile gear. Then one starts misbehaving and your stomach drops.
First thing I’d do, unplug it and stop poking at it. If files were deleted, or the drive is freezing, reconnecting it over and over is how you make a bad situation worse. More reads, more writes, more chances for the drive to chew up what’s left.
Open Disk Management from the Start button menu. If the drive shows up there with the right size, I’d still try recovery myself. If it’s missing there, or you hear clicking, buzzing, or grinding, I’d quit right there and look at a recovery lab. Noise like that usually means the problem is no longer software.
What worked for me
If the computer still sees the drive, I’d start with recovery software. After trying a bunch over time, the one I keep coming back to for My Passport drives is Disk Drill. Main reason, it reads the file systems these drives usually show up with, NTFS, FAT32, and exFAT, and it doesn’t bury the useful stuff behind a mess of menus.
  1. Install it on your computer, not on the WD drive.
  2. Then connect the My Passport.
  3. Select the drive and start the scan with 'Search for lost data.'
  4. Pick 'Universal Scan' if you want the thorough pass.
  5. While it scans, check the found files. I usually look in 'Deleted or lost' first, then 'Reconstructed.'
  6. The preview tool matters more than people think. If a photo opens or a document previews cleanly, I treat it as a solid sign the file is recoverable.
  7. Select what you want and hit 'Recover.'
If your case is simpler
I’ve also used Recuva for smaller mistakes. If you deleted a couple files and the drive is otherwise normal, it’s fine. Old interface, limited depth, but for a plain accidental delete, it does the job often enough.
For nastier stuff, like a lost partition or a disk suddenly marked uninitialized, TestDisk is one of those tools people mention for a reason. It’s free, and in some cases it restores the partition table so the files show back up without a full recovery pass. I would not call it friendly. One wrong step and you’re in deeper trouble. If you’re not comfortable reading each prompt slowly, I’d skip it.
The part people miss with My Passport drives
  1. Don’t remove the drive from the enclosure unless you already know what you’re dealing with. A lot of My Passport models use hardware encryption through the USB board inside the case. I learned this the hard way years ago. Pull the bare drive out, hook it up another way, and the data looks scrambled or the volume shows as RAW. If the port on the enclosure is damaged, a repair tech soldering the original board is usually the safer route.
  2. If you turned on WD Security and set a password, you need that password. No cute trick around it. The drive has to be unlocked first with WD’s tool before recovery software will see usable files.
After you get your data back, set up some kind of backup. Doesn’t need to be fancy. WD points people to Acronis now, which is fine, but I’ve also kept things simple with a second external drive plus OneDrive or Google Drive for the files I’d hate to lose twice. Once was enough for me tbh.
Yes, if you formatted the WD drive and then stopped using it, your recovery odds are often decent. Quick format is the best case. Full format is worse, esp on newer Windows versions, because it writes over more data.
I agree with @mikeappsreviewer on one big point. Stop writing anything to the drive. I disagree a bit on partition repair as an early move after a format. If the disk was healthy before, file recovery first is safer than trying to rebuild structures and hoping nothing gets worse.
What I’d do:
  1. Check if the drive mounts and shows the correct size.
  2. Do not copy files onto it.
  3. If the data matters a lot, make a byte-for-byte image first with something like HDD Raw Copy Tool or ddrescue.
  4. Scan the image, or the drive, with Disk Drill. It’s one of the better options for formatted WD external hard drive recovery because it handles exFAT, NTFS, FAT32, and does a solid job with photo and document signatures.
  5. Recover files to a different disk.
A few practical points people skip:
  • File names and folder structure often survive a quick format, but not always.
  • Photos and office docs usually recover better than big fragmented video projects.
  • If BitLocker or WD security was active, recovery gets harder fast.
  • If SMART shows lots of bad sectors, image first. Dont keep rescanning the original.
For a plain accidental format on a healthy WD drive, software recovery works often enough to try before paying a lab.
If you want a plain guide, this Western Digital formatted drive recovery guide is decent: watch this WD external hard drive recovery walkthrough.
Yes, usually you can recover data from a WD external hard drive after formatting, but the answer depends on what kind of format happened and whether you kept using the drive after.
I mostly agree with @mikeappsreviewer and @cacadordeestrelas, but I’d push one thing harder: before doing multiple deep scans, think about making a clone/image first if the files are truly irreplaceable. Recovery software is great, but repeated reads on a flaky external can turn a recoverable drive into a paperweight real fast. This explains why creating a disk image before data recovery can protect your files pretty well.
A few extra points that matter:
  • Quick format = much better chance.
  • Full format = worse, but not always hopeless.
  • SSD-based externals are trickier because TRIM can wipe recoverable data faster.
  • WD externals that were encrypted or password-locked can complicate everything a lot.
I would not start by trying to ‘repair’ the formatted drive. That can go sideways. Safer move is recovery to another disk. Disk Drill is a solid choice here for WD external hard drive formatted data recovery because it can scan for both lost filesystem records and file signatures. Save anything recovered somewhere else, never back onto the same WD drive. If previews look fine, that’s usually a decent sign.
If the drive is clicking, disconnecting, or painfully slow, stop. That’s more lab territory tbh.
Yes, often recoverable after a format, but I’d split it into two questions: was it just formatted, or is the drive also unstable?
I mostly agree with @cacadordeestrelas, @sternenwanderer, and @mikeappsreviewer on stopping use immediately. Where I differ a bit: before even thinking about software, check the WD’s health with something simple like CrystalDiskInfo or the SMART readout in another utility. If health is bad, don’t do a long recovery session on the original drive.
A few WD-specific gotchas people miss:
  • Some My Passport models rely on the USB bridge for hardware encryption, even without you setting a password manually.
  • If the enclosure board fails, shucking the drive can make recovered data appear unreadable.
  • If the format changed file system type, recovery quality can drop even if raw files are still there.
About Disk Drill:
Pros:
  • Good support for NTFS, exFAT, FAT32
  • Nice previews, useful for checking photos/docs before recovery
  • Easier to sort through found files than many tools
  • Deep scans can take a long time
  • Raw recovery may lose original names/folders
  • Paid recovery limits can annoy people
If the drive is healthy, Disk Drill is a reasonable first software pass. If it disconnects, clicks, or crawls, skip DIY and go to a lab. The biggest mistake after formatting is trying too many tools in a row on the same physical disk.
