My Wuben G5 suddenly stopped working right after normal use, and I’ve already tried basic troubleshooting with no luck. I need help figuring out what might have caused it and whether there’s a fix before I replace it.
If your G5 died right after normal use, I’d check the simple failure points in this order.
Charge path.
Use a known good USB-C cable and a low power charger, 5V 1A or 2A. Leave it for 30 to 60 min. Some tiny lights look dead when the cell drops too low. Watch for any charge LED. No LED at all points to the port, board, or battery. -
Button lockout.
A lot of pocket lights get ‘stuck off’ from lock mode or weird UI state. Hold the switch for 5 to 10 sec. Then try single click, double click, and triple click. If the switch feels mushy or dead, the button may have failed. -
Battery contact issue.
If the G5 version you have allows access, check for dirt, bent contact, or a shifted insulator ring. Clean contacts with isopropyl alcohol. Let it dry fully. If it has a built in cell only, skip this. -
Thermal or impact damage.
If it got hot in use, or took a drop, solder joints crack. Small keychain lights do this more than bigger lights. A dead light right after use often means battery protection tripped, or the driver board failed. -
Water.
Even ‘water resistant’ is not magic. A little moisture in the switch or port kills these.
Best quick test, plug in charge, wait 30 min, try unlock sequence, inspect port with a flashlight. If still nothing, it’s likley a bad cell or driver. At tht point, warranty makes more sense than replacement parts. Wuben support is usally decent if you send order date, serial if any, and a short video showing no response.
One thing I’d add to what @chasseurdetoiles said: if it died right after turning it off normally, I’d strongly suspect the switch board or driver, not just the battery. People jump to “dead cell” fast, but on these tiny combo lights the electronics fail just as often.
A couple checks that are a bit different:
- Plug it into a computer USB port, not a wall brick. Sometimes a bad charge circuit will at least blip or get warm.
- While connected, gently wiggle the USB-C plug. If the charge light flickers, the port solder joints are probly cracked.
- Check for weird heat. If it gets warm while charging but never responds, that can mean the battery is taking power but the control board is toast.
- Smell test, seriously. Burnt electronics smell is a real clue on small lights.
- If the clip/body got tweaked, make sure the housing isn’t slightly seperated. Some of these compact lights lose internal contact from a tiny twist or drop.
Also, if the light has aux/signal features, make sure it’s not stuck in some odd mode where the main emitter looks dead but the unit is technically on. Rare, but I’ve seen stranger stuff.
If there’s zero output, zero indicator, zero reaction on charge across multiple cables, I wouldn’t sink much time into it. That’s usually board-level failure, and these are not fun to repair unless you already do microsoldering. At that point warranty claim > replacement attempt, easy.
I’d add one angle that @chasseurdetoiles didn’t really hit: lockout or stuck switch logic. The G5 has enough UI weirdness that a failed button press can look exactly like a dead light.
Try this before writing it off:
- Clean the button area with a little isopropyl on a swab. Pocket grit can jam tiny e-switches.
- Hold the button for 15 to 20 seconds, then release, then try single click, double click, and long press.
- Leave it on charge for a full hour even if no indicator shows, then test again.
- If it has taken a drop lately, tap the body lightly in your palm. Not hard. Sometimes an internal contact springs back just enough to confirm a mechanical issue.
- Check the lens and side LED area for condensation. Moisture kills these little combo lights fast.
I slightly disagree with the “don’t sink time into it” part if the failure was sudden after normal use and there was no heat or smell. That sometimes points to switch failure, which is annoying but not always catastrophic.
Pros for the Wuben G5: compact, useful feature set, easy carry. Cons: tiny integrated electronics, harder to service, not much margin for impact or moisture. If it still shows absolutely nothing after the reset-style button tests and a long charge, I’d call it a warranty case, not a battery problem.
Skip further troubleshooting and use the warranty route. Record a short vedio showing the G5 failing to start, then photograph the serial number and charging port. Contact Wuben support or the original seller with your order number and reciept. State it stopped after normal use, with no drop, water, heat, or smell. Ask for a replacement, refund, or prepaid return label. This avoids opening the sealed body and risking warranty denial.
