I’m trying to learn how to make AI from scratch, but I got overwhelmed by all the tutorials, coding tools, and machine learning terms. I’m not sure where to start, what skills I need, or which beginner-friendly resources actually work. I need help finding a simple path to build an AI project without wasting time on the wrong steps.
Start small. Don’t try to “make AI” all at once. You need 3 layers.
Core skills.
Learn Python first. Variables, loops, functions, lists, files.
Time: 2 to 4 weeks if you study daily. -
Math you need.
Focus on algebra, basic calculus, and statistics.
You do not need advanced math on day 1.
Key topics:
- Linear equations
- Derivatives
- Probability
- Mean, variance
- Matrices
- Machine learning basics.
Learn supervised learning first.
Start with:
- Linear regression
- Logistic regression
- Decision trees
- Neural network basics
Best path for beginners:
- Python: Automate the Boring Stuff
- Math: Khan Academy, 3Blue1Brown
- ML: Andrew Ng Machine Learning Specialization
- Practice: Kaggle, scikit-learn docs
Build tiny projects early.
- Spam classifier
- House price predictor
- Digit recognizer
- Sentiment analysis on movie reviews
Use tools with low setup pain.
- Python
- Jupyter Notebook
- NumPy
- pandas
- scikit-learn
- Matplotlib
Later, move to:
- PyTorch
- TensorFlow
- Hugging Face
A simple roadmap:
Month 1: Python
Month 2: Math and data analysis
Month 3: First ML models
Month 4: Small projects
Month 5+: Deep learning
One more thing. “From scratch” sounds cool, but it slows you down. First learn to train models with libraries. After taht, study how backpropagation, gradient descent, and transformers work under the hood.
If you want the shortest path, do this:
Python, scikit-learn, 3 projects, then PyTorch.
Most people get stuck because they consume tutorials and build nothing. Build stuff early, even if it’s messy and kinda dumb.
I’d tweak @nachtdromer’s advice a bit: don’t frame it as “learn everything first, then build AI.” That’s where people stall out.
My take is split it into three tracks at the same time:
- coding track: enough Python to load data, loop, write functions
- concept track: what a model actually does, like inputs → patterns → prediction
- project track: one tiny thing you keep improving
A lot of beginners drown because tutorials throw math at them before they even know why it matters. Hot take: you can delay a chunk of the calc stuff longer than people say. Algebra, graphs, probability, and basic stats matter way more early on.
Also, “from scratch” means 2 different things:
- no-code tools avoided
- no libraries at all
For #1, sure, learn with Python.
For #2, honestly, that’s masochism for a beginner lol.
What I’d do:
- Pick one problem type only, like classification
- Learn to clean a CSV
- Train one model
- Measure accuracy
- Change something and see what breaks
That feedback loop teaches more than 20 vids.
Beginner trap list:
- installing 14 frameworks
- trying to learn LLMs first
- copying code you don’t edit
- watching “AI in 10 minutes” nonsense
If you want a practical first milestone, make a model that predicts yes/no from a spreadsheet. Boring? yep. But that’s actual ML.
After that, then go under the hood and write mini versions of stuff yourself, like gradient descent for a line fit. That’s the part people skip, and then they can “use AI” but not really explain it.
Short version: stop thinking “make AI.” Think “learn to solve one prediction problem with code.” That’s waaaay less overwhelming.
I partly agree with @nachtdromer, but I’d push one extra thing: spend a little time on problem framing before touching models. A lot of beginners fail because they ask “how do I make AI?” instead of “what exact input do I have, and what output do I want?”
Try this order:
- define one tiny task
- inspect real data manually
- make a dumb baseline first
- only then train a model
Example: if you want spam detection, first see how often “free” appears in spam. If a simple rule works 70 percent of the time, your model now has something to beat.
I disagree slightly with the “delay math” idea. You can delay heavy math, yes, but basic intuition for averages, probability, and error should start immediately or model results will feel like magic.
Also, don’t obsess over “from scratch.” For beginners, the real split is:
- build understanding
- build tools
You need both. Writing every algorithm from pure Python too early is slow. But using libraries without ever checking predictions, errors, and edge cases is how people fake-learn ML.
A good early stack:
- Python
- pandas
- matplotlib
- scikit-learn
- Jupyter
Skip deep learning at first unless your project truly needs images, audio, or text generation.
Pros of ':
- can help organize your learning path if it’s a structured resource
- may save time versus piecing together random tutorials
Cons of ':
- if too broad, it can add to overwhelm
- if too theory-heavy, you may stall before building anything
Best beginner milestone, in my opinion: make a model, compare it to a dumb baseline, explain why it wins or loses in plain English. If you can do that, you’re actually learning AI, not just running code.
