How can I update my iPhone when I have no storage left?
My iPhone says there isn’t enough storage to install the latest iOS update, and I’ve already deleted some apps and photos. I still can’t get the update to download, and I need help figuring out what else I can safely remove or if there’s another way to update my iPhone with no storage available.
I ran into this on my own iPhone and the storage warning felt fake at first, because Settings showed a few GB open. The catch is the updater wants more than the download size. A typical iOS package might sit around 2 GB, but the phone also needs room to unpack files and finish install steps. If you're moving to a big release like iOS 26, I’d try to free up 10 GB to 15 GB first. Less than that, and installs start failing, or the phone hangs mid-update.
If you’re done picking off random photos and getting nowhere, this is the order I’d use.
Use a computer first
This saved me the most time. Plug the iPhone into a Mac or Windows PC and run the update there. On Mac, use Finder. On Windows, use iTunes. The big difference is where the heavy file work happens. Your computer downloads the update and handles the unpacking on its own drive, so your iPhone needs less free space for the install itself.
Before you click Update, make a full backup to the computer. I did this once before a messy update and was glad I had it.
If the phone is still a mess storage-wise, there’s a harsher route. Back up the iPhone, erase it, set it up again, then restore from the backup after iOS installs. During setup, the phone usually pulls the newest iOS version for your model. It works, but I’d treat it as the last stop before giving up.
If you don’t want to wipe the device, start deleting the stuff with the biggest payoff.
Photos and videos
Videos usually eat space faster than anything else. I’ve seen two old 4K clips free more storage than hundreds of photos. If you want the fastest route, use a cleaner app instead of scrolling through the camera roll for an hour. I’ve had decent results with Clever Cleaner. It sorts large videos and groups similar shots, which helps when your gallery is full of near-duplicates.
One thing people miss, I missed it too the first time. Open Photos, go to Recently Deleted, then empty it. Until you do, iPhone keeps the files around for 30 days and the space does not come back.
Apps
I don’t bother with offloading when storage is this tight. Offloading leaves Documents & Data behind, and in some apps that junk is the main problem. Social apps are bad for this. TikTok, YouTube, Instagram, they pile up cached files over time.
I delete the app outright if I haven’t used it today or yesterday. You can reinstall it after the update, and a fresh install is often smaller anyway. A few minutes of setup beats fighting the storage meter for an hour.
Hidden data
There are two places I check every time because they collect junk quietly.
  1. Safari cache. Go to Settings > Apps > Safari, then tap Clear History and Website Data. I’ve seen this clear out 500 MB to 1 GB on phones people swore were already cleaned up.
  2. Message attachments. Group chats are brutal for storage. Go to Settings > General > iPhone Storage > Messages, then open Review Large Attachments. You’ll find old videos, images, and files sitting there. You can remove them without deleting the conversation itself, which is nice.
If I were doing this again, I’d go in this order: computer update first, big videos second, full app deletions third, Safari and Messages cleanup last. Usually that’s enough to get the update through without wiping the whole phone. If your free space is still sitting in the danger zone, I wouldn’t trust an over-the-air install tbh.
One thing I’d add to what @mikeappsreviewer said, check for the old iOS update file itself. iPhone sometimes downloads part of an update, fails, then keeps the package sitting there and eating space.
Go to Settings > General > iPhone Storage. Scroll down and look for iOS or Software Update. Delete it if you see it. Then restart the phone and try again. This frees 2 GB to 5 GB on some phones.
Also check these spots.
Mail app, delete big attachments or remove and re-add a large mail account.
Podcasts, downloaded episodes pile up fast.
Music and Netflix/YouTube downloads, these are easy wins.
Files app, look in On My iPhone and Downloads. People forget this one alot.
I don’t fully agree with deleting tons of apps first. Sometimes the bigger issue is cached media and failed update files, not apps.
If your photo library is the problem, Clever Cleaner helps sort duplicates and large videos faster. I found this Reddit review of Clever Cleaner for freeing iPhone storage useful.
One more trick. Turn off Low Power Mode, plug into Wi-Fi, then restart before updating. iOS updates fail in weird ways when the phone is low on both storage and system resources.
I’d actually not jump straight to wiping the phone unless you’re totally stuck. @mikeappsreviewer and @chasseurdetoiles already covered the big obvious wins, so here’s the stuff that tends to get missed:
Go to Settings > General > iPhone Storage and wait a minute. Seriously, wait. That screen recalculates slowly, and sometimes “System Data” or app sizes shrink after iOS finishes indexing. I’ve seen people delete stuff for no reason because the numbers were lagging.
Then try this:
  • Enable Offload Unused Apps temporarily. Yeah, I know one reply kinda dismissed offloading, but for some people it’s the fastest low-risk move because you keep app data.
  • Delete old voice memos if you use that app. These can be weirdly huge.
  • Remove downloaded maps in Apple Maps or Google Maps.
  • Check Books and audiobooks downloads
  • Restart after every major cleanup, not just once. iPhone can be dumb about reclaiming space untill after a reboot.
Also, if you use iCloud Photos, make sure Optimize iPhone Storage is on. If it’s off, your phone may still be hoarding full-res originals locally, which is brutal on smaller devices.
One more thing people overlook: if you’re on the beta track or ever were, remove the beta update profile/channel if applicable. Those update files can get messy.
If photos are still the bottleneck, Clever Cleaner is honestly useful for spotting large videos and duplicate junk faster than doing it by hand.
And if you want more of a set-it-and-forget-it angle, this guide on automating iPhone storage cleanup is worth a look.
If none of that moves the needle, computer update is probly the least annoying next step.
I’d add one angle the others did not really stress: don’t trust “Available” storage if iOS is still doing background indexing. After deleting a bunch of stuff, plug the phone in, lock it, leave it on Wi‑Fi for 30 to 60 minutes, then check storage again. I’ve seen space come back only after the system finishes cleanup.
A couple extra things to try:
  • Delete old Siri voices if you downloaded extra ones
    Settings > Accessibility > Spoken Content > Voices, or check Siri language/voice downloads
  • Remove unused keyboard dictionaries/language packs
  • Turn off and back on Sync Library in Music only if you use Apple Music and have tons of cached tracks
  • Check third-party cloud apps like Dropbox, OneDrive, Google Drive for offline files
  • Trim Notes attachments since scanned PDFs and embedded images can get huge
I slightly disagree with going straight to app deletion as the main strategy. For a lot of people, offline files and media caches are the real pigs, not the apps themselves.
If photos are still the roadblock, Clever Cleaner is decent for quickly finding duplicate shots and big videos.
Pros: fast scan, easy to spot junk, useful for photo-heavy phones.
Cons: mostly helpful for photo/library cleanup, less useful for system data, and some people prefer doing it manually for control.
Between what @chasseurdetoiles, @espritlibre, and @mikeappsreviewer already covered, the only other practical fallback is this: update through Recovery Mode on a computer before doing a full erase. That can sometimes reinstall iOS cleanly when normal update methods keep choking on storage.
