I’m trying to stream videos and photos from my iPhone to my Roku TV, but the TV isn’t appearing as an AirPlay option. Both devices are on the same Wi-Fi network. What settings or apps do I need to connect them?
Most Roku devices actually support AirPlay natively these days (Roku Ultra, Streambar, most Roku TVs). So there’s a good chance you don’t need any third-party app at all.
Step 1: Check if AirPlay is enabled
Go to Settings > Apple AirPlay and HomeKit on your Roku. If it’s there (it usually is on models from the last few years), you’re set — just use Control Center on your iPhone.
If you just want to watch a movie or show (Netflix, YouTube, etc.):
Easiest option — skip mirroring apps entirely:
- Open Control Center on your iPhone, tap Screen Mirroring, select your Roku.
- Or even simpler: just open the Roku’s own native app (Netflix, Disney+, etc. are already installed on Roku) and log in there — no need to cast from your phone at all.
If AirPlay isn’t available on your Roku model, or you want to mirror your whole screen / cast personal photos, videos, music:
Older Roku models (some Roku Express, older Roku Sticks) don’t have AirPlay support. In that case, you’ll need a third-party app to bridge the two.
Recommended: the DoCast iPhone app
Connect both your iPhone and Roku to the same Wi-Fi, open DoCast mirroring app, select your Roku from the list, and either mirror your screen or cast media straight from your library. Free version handles unlimited photos; video/music sessions are time-capped, full mirroring needs premium.
Alternatives worth checking out:
- Replica – comparable feature set, works with Roku too.
- AirScreen – markets itself specifically around Roku/Fire TV compatibility, worth a look if DoCast doesn’t fit your needs.
Quick tips:
- Same Wi-Fi network for both devices, always the first thing to check.
- If AirPlay isn’t showing up as an option, make sure your Roku software is updated — go to Settings > System > System Update.
- If devices aren’t finding each other on a mirroring app, check your router isn’t blocking device-to-device discovery (sometimes called “AP isolation” in router settings).
- DRM-protected content (Netflix, Prime, Disney+) won’t mirror through third-party apps — use AirPlay or the native app on Roku itself instead.
Being on the same Wi-Fi isn’t enough if your iPhone has a VPN active, since it can block Roku discovery. Turn the VPN off, wake the TV, then reopen Control Center and check Screen Mirroring again before installing anything.
If the AirPlay menu exists on the Roku but discovery still fails, use Settings > Apple AirPlay and HomeKit > Reset Paired Devices, then restart the Roku from its System menu instead of just turning the TV off. Roku TVs often stay in standby, so a normal power-button cycle may not clear a stuck AirPlay service. After it restarts, unlock the iPhone and check Screen Mirroring again. A third-party app only makes sense if the Roku genuinely lacks that AirPlay menu.
If the Roku still has no “Apple AirPlay and HomeKit” menu after a system update, an iPhone setting won’t magically enable it. Check the exact Roku model under Settings > System > About. Older hardware may need a casting app or a newer Roku device.
If the menu is present, make sure AirPlay is turned on, then keep the TV awake while opening Control Center > Screen Mirroring on the iPhone. A detail people miss is mesh Wi-Fi or range extenders: both devices can show the same network name while sitting on separate network segments. Temporarily connect both to the main router’s Wi-Fi and avoid guest networks.
For photos and home videos, native AirPlay should work once discovery is fixed. Individual streaming apps may show a black screen or refuse mirroring because of copy protection, so use their Roku versions instead. Third-party mirroring apps are mainly a fallback for unsupported Roku models, and they won’t bypass those restrictions.
Roku’s “Screen mirroring” setting and Apple AirPlay sound like the same feature. They aren’t. The first is mainly Miracast for Windows and Android, so changing its prompt or allow settings won’t make an iPhone appear.
For the iPhone, the Roku must have Settings > Apple AirPlay and HomeKit. Open that menu, turn AirPlay on, and set access to devices on the same network. Then leave the TV awake and try Control Center > Screen Mirroring.
A quick test from the Photos app is useful too. Open a normal photo or home video, tap Share, then AirPlay. That avoids confusing an AirPlay problem with an app that blocks screen capture. If Photos works but a subscription video app shows black, AirPlay is fine. Use that service’s Roku app instead.
If the Roku still does not appear:
- Restart it through Settings > System > Power > System restart
- Restart the iPhone
- Disable VPN, Private Relay, and any guest Wi-Fi temporarily
- Keep Bluetooth enabled during setup
- Check that the Roku is not connected through Ethernet to an isolated router segment
- Update both devices, then reset paired AirPlay devices on the Roku
Don’t reset the iPhone’s entire network configuration yet. That deletes saved Wi-Fi networks and is rarely the clever first move.
If there is no Apple AirPlay and HomeKit menu after the Roku update, check the exact model under Settings > System > About. At that point, a casting app can handle personal photos and unprotected videos, but it will not turn unsupported hardware into full native AirPlay or defeat copy protection. A newer Roku stick may be less annoying than maintaining another mirroring app.
Fast TV Start uses extra standby power, so don’t enable it blindly, but it can explain why a Roku TV disappears from AirPlay whenever the screen is off. For testing, fully wake the TV and leave it on the Roku home screen. If AirPlay works only while the TV is awake, look under Settings > System > Power > Fast TV Start and decide whether standby discovery is worth the additional power use.
@@mikeappsreviewer is right about Roku’s regular Screen Mirroring menu being unrelated to iPhone mirroring. The useful test is a photo from Apple’s Photos app: open it, tap Share, choose AirPlay, and see whether the Roku appears. This separates basic device discovery from full-screen mirroring and from streaming apps that block mirrored video.
If you switch to a third-party casting app, check an iPhone permission that hasn’t been mentioned yet: Settings > Privacy & Security > Local Network. The app must be allowed there or it can report that no Roku exists even when both devices are connected correctly. That permission affects the casting app, not the native Screen Mirroring control.
So I’d test with the TV awake first. If the Roku appears, native AirPlay is working and you can address standby behavior separately. If it never appears and there is no Apple AirPlay and HomeKit menu after updating the Roku, check the model number rather than spending more time changing iPhone settings. An app may still send photos or unprotected files to older hardware, but it won’t add true system-level AirPlay support.
