I’m cleaning up a project handoff folder with 47 files, including PDFs, meeting notes, and drafts with nearly identical names. I tried sorting them into topic folders and renaming files from their opening paragraphs, but some documents cover several topics, and I still can’t tell which drafts are worth keeping.
Would GPT-Dot be a reasonable next step, or would I still be doing most of the sorting manually? I haven’t used it for this before. Can it suggest a folder structure and flag possible duplicates for review without changing the originals, or should I prepare an inventory before trying anything with the files?
Start with an inventory, not another round of renaming. I’d try GPT-Dot for a proposed sorting plan, but leave the keep-or-delete decisions to you. You don’t need to write the inventory by hand first. Save a basic file listing as your baseline, then ask it to produce an annotated inventory from a working copy of the folder.
Before connecting anything, check its access. Dots can have permission to read without permission to change things, depending on the connection, but they can also inherit permissions from existing connected apps. My preference would be a separate copy and read-only access wherever available. Give it an explicit “report only, no moves, renames, edits, or deletions” instruction too, rather than treating that instruction as your only protection.
For the first pass, I’d ask: “List each original filename and path, summarize the whole document, suggest a primary folder and secondary topic tags, and flag possible duplicate or revision groups. Explain each flag with specific similarities and differences. Mark anything you couldn’t fully read. Return the report here without changing files.” For your multi-topic documents, I’d favor one primary location plus tags in the inventory instead of trying to make the folder tree express every subject. Review that report before asking for proposed filenames.
For draft review, ask “What would I lose by archiving this version?” rather than “Which version is best?” Have it identify unique decisions, comments, unresolved questions, and passages in each candidate. Keep exact-copy checks separate from judgments about similar content, and request a proposed keeper with reasons, not an automatic deletion list. That’s the division of labor I’d aim for: let the tool prepare comparisons and a folder proposal, while you verify the ambiguous groups and decide what belongs in the handoff.
Renaming can make a handoff harder if people are still looking for filenames quoted in emails or meeting notes. I’d turn @emma1996’s inventory into a “start here” index and preserve the old names there if you rename anything. That gives the next person a way to find the document without needing to guess your new naming scheme.
If those drafts disagree, manual review matters more than automated sorting. I’d use @emma1996’s index to flag which documents are approved, superseded, or still unconfirmed, rather than making every draft look equally ready to use.
Don’t spend more time reviewing the sorting report than you would have spent sorting the folder. For a handoff of this size, I would compare the two by the amount of review they require, and not the speed at which they get you a nicely-formatted folder tree.
@emma1996’s inventory gives you a useful baseline, but I’d hold off on requesting detailed annotations for everything. Try a small, deliberately awkward sample first: a vague filename, a document covering several topics, and a couple of look-alike drafts. Ask for proposed destinations without changing anything. Then check whether you can accept those suggestions with a quick inspection or whether you have to read every document closely anyway.
That’s the comparison I would care about. If the suggestions are easy to verify then expanding the automated pass would be reasonable. If you’ve read all the files and you’re going to review a summary of the same file you’ve created a second review task. The manual sorting is less appealing when compared to an instant generated report but the report is not the end handoff. Your checking time should be part of the comparison.
I’d let the sample decide on how much automation it would be reasonable to make rather than a commit on the entire folder. You may find obvious documents to be faster to place yourself and a few confusing groups could use some help on comparisons. Or perhaps the proposed sort could save enough effort to be used across the board. Either way I would not require a fully annotated catalog just to get this folder out the door.
Sorting unrelated PDFs by topic is different from sorting a handoff where a meeting note explains why a particular draft changed. In the second case, a tidy folder tree can separate documents that someone needs to read together. I’d check for those relationships before committing to topic folders.
That’s where I’m a little skeptical of @socket.git’s quick-inspection test. A destination can look correct in isolation and still make the handoff harder to follow. Say a draft belongs under “Requirements,” while the notes explaining a disputed requirement land under “Meetings.” Both placements are defensible. But the next person now has to reconstruct the connection, assuming they even know there’s a connection to look for. I’d judge the proposed sort partly on whether it preserves that context, not only on how quickly you can approve each placement.
For the confusing groups, I’d give GPT-Dot a narrower task: identify explicit references between documents. Ask which file refers to another draft, records a decision about it, or supplies an attachment it mentions. Require the passage supporting each proposed connection, and leave unresolved references unresolved. Similar wording alone wouldn’t convince me that two files belong together. This is a more useful comparison task to me than generating another set of topic labels, though you’d still need to check the evidence.
You don’t need an elaborate system to preserve those connections. Keep a related packet together where that makes sense, or put a short “read with” note in the handoff index. Then try following an actual question through it, such as “Why did this requirement change?” If the proposed organization gets you to the draft but hides the explanation, I’d change the organization. A folder can look messy and still carry context worth keeping.
The trap that no one seems to mention, that half of a handoff folder is likely to be an image of a printed meeting note that summarizer will ignore or guess at, and a summarizer’s inventory is likely to miss the files that you most need to read by hand, while appearing to have everything. So before trusting any annotated report, you need to check how it handled the image-only PDFs; if it didn’t flag them as unreadable, you should distrust any confident summaries of what they said.
I’m with @socket.git on starting small, but I’d stack the awkward sample with your scanned junk on purpose, not just the look-alike drafts. That’s where the time actually goes.
Some of the mess may need an answer from the person handing it over, rather than a better sorting method. If two drafts disagree and neither records why, I wouldn’t spend an afternoon trying to infer intent from the wording. “Which of these did you actually send out?” is a question I’d take back to the sender.
That’s a third option in @socket.git’s time comparison: automated sorting, manual sorting, or asking someone who knows. I’d collect the few questions that would actually change the handoff and send them together. Which draft was circulated? Was this proposal dropped or just left unfinished? Is the attachment mentioned in these notes missing from the folder? Keep those questions tied to the original filenames so the person can answer without learning your new organization.
For me, the useful automation task would be turning those ambiguities into a short question list, rather than producing increasingly detailed summaries. I’d still place the straightforward files myself. If the original owner isn’t available, leave a plain note saying what couldn’t be confirmed and keep the affected documents together for now. I’d rather receive a folder with an explicit unanswered question than have to work out whether a tidy arrangement represents someone’s decision or someone’s guess.
Copying a folder before anything touches it is a great idea, but beware the effects it has on your timestamps. Depending on what you’re copying, ‘date modified’ can be overwritten across all files to today, and on a disorganized handoff, that date might be the only sure way of telling which draft was finished most recently. Once it’s gone, you’re left to guess based on wording, which is exactly the sort of guesswork everyone here has so much trouble avoiding. Keep a bare listing of the original dates somewhere safe before cloning anything, and keep it there.
@mike34 is right that some of this just needs an answer from the sender, and I’d push that further. The questions worth asking are the ones no amount of reading will settle. Which draft actually went out, whether a half-finished proposal was killed or paused, whether a missing attachment was ever real. A summarizer can line those up as candidates, but it can’t tell you intent, and neither can you by rereading the files for the third time.
In which I am gently dissenting with the framing of ‘start small and test the sample’ as a whole, because it’s framing the sort as the problem. For a handoff, the hard part is going to be the stuff that never made it into any files. A decision, that was made in a hallway conversation, a requirement that everyone silently dropped. There’s nothing an inventory is going to catch, no matter how good the annotations are going to be.
@crystalpilot6433’s point about scanned notes is the one I’d take most seriously. Image-only PDFs don’t just get skipped, they get confidently paraphrased from the filename or a stray caption, and that fake summary reads exactly like a real one. If you want a quick gut check, open the two or three files you remember being scans and see whether the report’s description matches what’s actually on the page. If it’s inventing content there, assume it’s shakier everywhere else too.
Honestly, for 47 files I’d set a ceiling on this. Place the obvious ones yourself in an afternoon, let a tool help only on the look-alike cluster and the reference-tracing @fusioncircuit9113 described, and ship the folder with a short note listing what’s unconfirmed. A handoff that admits three open questions beats a spotless tree that hides them.
