How do I stop GPT-Dot from giving me so many progress updates? I’m using it to help draft a handoff document for my team, and the running commentary keeps interrupting the actual output. I asked it to only show the finished draft, but it still narrates what it’s doing.
I wouldn’t make “stay silent” absolute, since you still want to hear about anything blocking the draft. Try this in the conversation handling the document: “Deliver the finished handoff document in your next response. No acknowledgment, plan, progress reports, or closing commentary. If a missing detail isn’t essential, mark it [TBD] rather than interrupting. Ask a question only if you cannot produce a useful draft without the answer.” I’d try that narrower instruction before spending more time arguing with the narration.
Don’t keep appending “stop the updates” without checking what else you’ve asked for. Look through the original brief and any saved instructions for things like “explain your approach,” “keep me informed,” or “work through this with me.” If those are there, remove them for this task. @kevin_git’s wording gives a clear output boundary, but I’d rather remove a conflicting request than add another rule on top.
For a handoff, I’d separate drafting from review: ask for the document now, and you can always ask for an explanation of its choices later if you need one. Give it the actual section headings you want, such as ownership, open issues, and next steps, and that the response begin with the document title. That way, you get a concrete format to enforce instead of another round of arguing how quiet it should be.
You may need to give it a fallback for missing information, rather than just asking it to stay quiet. @kevin_git’s point about conflicting instructions makes sense, but I’d check whether the interruptions are requests for decisions or permission to continue. For a handoff draft, you probably don’t need to resolve every gap before getting something usable.
Try: “Return the handoff draft only. Do not send progress reports or ask for approval between sections. Where information is missing, write [TBD] instead of guessing or pausing. Put any unresolved questions at the end under ‘Needs confirmation.’” That gives it somewhere to put uncertainty without interrupting the document. I wouldn’t use “make whatever assumptions you need” just to stop the chatter, especially for owners, deadlines, or commitments.
Be careful when overriding handoff briefs before seeing where those updates are originating from. You may be removing useful instructions before fixing the interruption.
I’m a bit confused about what you’re referring to by ‘progress updates’. Are you talking about the user writing ‘I’ll work on the ownership section next’ as part of the conversation, or are you referring to temporary lines that appear as the application is working on fulfilling the request? These seem like two entirely different problems to me, and I would have expected an instruction about what to write to be targeting the first case. I wouldn’t expect it to be affecting everything the application displays.
@nanopilotsync’s suggestion makes sense if the commentary is actually part of the conversation. Before editing saved instructions, though, I’d try a tiny throwaway request in a separate chat: “Write a handoff note from these facts: the draft is complete, review is pending, and the owner is [TBD]. Return only the note.” No files, no extra tasks. This wouldn’t prove what’s wrong, but it would give you something simpler to compare with the document task.
Then look at what’s left of the response once it’s done processing the response. If the extra narration is still there but as messages, you’ve got a concrete example of the output instruction not being followed. If they disappear and only the note remains, I’d check if your app has a display or notification toggle for them. I don’t know if your setup has something like that, so I wouldn’t be going off looking for a supposedly guaranteed ‘silent mode’ either.
The missing detail for me is where the interruption would be placed in: in the draft, in separate chat messages, or in a temporary status bar area. I’d work that out before trying another run of a prompt that’s stricter. You’ve already requested the finished document, it really shouldn’t be turned into a second writing project just to phrase that request properly.
Stopping the response at the first progress message risks leaving you with commentary and no handoff. If you’ve been canceling and retrying whenever it starts narrating, I’d let a run finish before spending more effort on a stricter prompt. Otherwise, you’re judging the opening chatter without finding out whether it eventually delivers the document.
I agree with @matrixhq about separating app status from actual messages, but I wouldn’t turn this into much of a troubleshooting project while the handoff is due. My immediate priority would be rescuing the work. If a completed draft is buried in the conversation, ask: “Extract the completed handoff into a standalone document. Preserve its contents. Exclude all conversation about writing it.” That’s a cleanup request, not another invitation to plan, research, or revise. If your setup supports creating a file, that would be my preferred destination. Otherwise, a separate response is enough.
The distinction matters: getting a clean deliverable is not the same as stopping the updates. A separate document won’t necessarily make the chat quieter, and I wouldn’t claim that any particular wording guarantees silence. It does give you something to send your team without manually picking the handoff out of a running conversation.
Once you have that, I’d stop negotiating with it. A clear output-only instruction should be enough to communicate what you want. If the unwanted messages persist, keep the original request and a representative response as an example to report through whatever feedback channel is available. You shouldn’t need an increasingly elaborate set of instructions just to receive a document without a play-by-play.
Realistically, you are not going to get perfect silence out of it every time, and chasing that is a part of why this is worse than it is. These models tend towards narrating because they are tuned to show their work. A good output-only instruction cuts most of it, but expecting zero stray lines on a long multi-section task makes you liable to continue fiddling.
@matrixhq’s split between app status and actual chat messages is the thing I’d nail down first too, because the fix is completely different depending on which one it is. If those ‘working on the ownership section’ lines vanish once the response finishes rendering, they were never part of the output and no prompt wording will touch them. That’s a client behavior, not the model ignoring you.
Where I’d push back a little is on the idea that the right move is another, stricter prompt at all. From what I’ve seen, once you’ve given a clear instruction to return only the document and it’s still chattering inside the actual text, more rules tend to make things worse, not better. You end up with a model so busy obeying a wall of constraints that it reintroduces meta-commentary about following them. Keep the instruction short and stop editing it.
One small thing people forget with handoffs specifically: a lot of the ‘progress updates’ are really the model asking permission because it hit something it thinks needs a human decision, like who owns a task. @mr_node’s [TBD] plus a questions-at-the-end approach handles that better than any silence command, because you’re giving it a legal place to park uncertainty instead of forcing it to either guess or interrupt. If you only tell it to be quiet without that outlet, it’ll go quiet and then guess, which is worse for a document your team actually relies on.
So my thinking is that you need to give it the outlet, keep the format instruction short, let one run finish before judging it, and see if the lines survive the rendering. If they do and the wording is already clear, it’s a bug to report, not a prompt to rewrite for the tenth time.
A permanent “never give updates” instruction could get in the way when you actually want progress reports on another task. I’d use @kevin_git’s output-only wording with “For this handoff draft only” at the start, rather than saving it as a blanket preference. This document needs less commentary, not a lifetime vow of silence.
