Can You Mirror iPhone to Chromecast?
I’m trying to show photos and a browser page from my iPhone on a TV that has a Chromecast connected. Both devices are on the same Wi-Fi network, but I don’t see a normal screen mirroring option for the Chromecast in the iPhone’s controls. I can cast from certain apps, but that doesn’t help when I need the entire screen, which is getting irritating.
Can you mirror an iPhone to Chromecast directly, or does full-screen mirroring require a separate app or another workaround? If it does require an app, are there any limitations with audio, rotation, or keeping the connection stable that I should expect?
A coworker recently wanted to put an iPhone game on a TV through a Chromecast, and I realized I was way behind on how these devices work together. I assumed the iPhone’s Screen Mirroring menu would handle it, but that isn’t the case.
Why the usual mirroring button doesn’t work
The basic issue is that Apple and Google use different systems. The iPhone relies on AirPlay, while Chromecast uses Google Cast, so a standalone Chromecast won’t normally appear as an option under Screen Mirroring.
For regular video or music, this may not matter. Apps such as YouTube, Netflix, Spotify, Disney+, and Google Photos already include a Cast button. As long as the iPhone and Chromecast are connected to the same Wi-Fi network and the Chromecast has been configured through Google Home, you can open one of those apps, tap the Cast icon, and choose the TV or Chromecast.
In that setup, the phone acts more like a controller than a mirrored display. The content plays on the TV, but the iPhone’s home screen, browser, games, and apps without Cast support stay on the phone.
There’s also a second possibility that depends on the television. Some Sony, Vizio, and Hisense smart TVs have both Chromecast built in and AirPlay support. With one of those models, the iPhone can use Control Center and Screen Mirroring directly, provided both devices are on the same network. That option doesn’t extend to standalone Chromecast dongles or the Google TV Streamer.
When you need the whole iPhone screen
If the goal is actual screen mirroring rather than playing content from a supported app, a third-party tool is needed. The DoCast screen mirroring app is one option I found while catching up. It requires iOS 15 or later and works with Chromecast generations, Google TV Streamer, and televisions that have Chromecast built in.
The setup is fairly direct. Both devices need to be on the same Wi-Fi network, then the Chromecast is selected inside the app. From there, you can mirror the screen, change the quality, or send individual photos, videos, and music files instead. The app claims a delay of under one second on a strong connection, along with auto-rotation and adjustable video quality.
Photo casting is free without a stated limit. Full mirroring and unrestricted video or music streaming require Premium, so the DoCast mirroring option makes more sense for someone who needs more than the occasional photo. There’s also a separate DoCast streaming overview covering those uses.
One catch is protected streaming video. Services such as Netflix and Apple TV+ may show a blank screen during mirroring because of copyright controls, so their own Cast buttons or built-in TV apps are the better route.
Has anyone here compared this setup with using a TV that supports AirPlay directly?
Check Settings > Privacy & Security > Local Network first, since a casting app cannot find the Chromecast if that permission is off even when both devices use the same Wi-Fi. Native full-screen mirroring still won’t work, and for occasional browser pages an HDMI adapter is usually less frustrating than dealing with app lag.
A good idea is to treat photos and web pages as two separate tasks rather than trying to find a universal Chromecast mirroring switch. To enjoy better resolution and reduced delay than it provides casting the phone screen, try opening the Google Photos app and choosing the Chromecast option in the Cast menu to view the desired photos. This method is generally more reliable and provides sufficient image quality for most cases.
The browser tab is the problematic part since Chrome on iPhone does not support casting website tabs the same way as the desktop version. The recommended solution is to use a web page’s in-built Cast function if the website has one. If not, one would have to use a third-party tool, an AirPlay-enabled TV, or a Chromecast device with a cable. Some mirroring apps feature an in-built browser that is easier to use than casting from Safari, but the experience may differ, and heavy use of the page’s functions may be unavailable.
One should also remember that third-party apps will most likely utilize Screen Broadcasting to mirror the content. As such, notifications, incoming calls, messages, and any other information that is shown on the phone’s screen can appear on the TV. To avoid that, one should enable Focus mode and close all the unnecessary background apps. Another thing to note is that the experience may not be as smooth as one would expect since there might be some delay between the actions on the phone and their reflection on the TV screen. Thus, this method is better suited for browsing websites rather than playing games or other graphically intensive activities and is generally ill-advised for any application that requires perfect synchronization between audio and video.
@0xdrone9 is right about checking Local Network permission, though I would check the Wi-Fi details too. Guest networks and routers with device isolation can prevent discovery even when both devices show the same network name. Temporarily disabling a VPN can help as well.
For your particular use case I would just cast the photos directly and only mirror if I am displaying the browser page. If you need this for pages regularly then an AirPlay friendly cable or built in support from Google would be better than relying on an application to handle the translation for you from Apples system to Googles system.
It is much easier to simply show a browser page as a picture than to try and navigate it live from the iPhone. In my experience, for a menu screen, a confirmation page, or an article, it is best to just take pictures of the relevant sections and cast these as photos. This way you avoid the lag, small controls, accidental scrolling, and potential exposure of notifications that comes with casting your screen.
If you need people to watch you navigate around on the phone you are going to need a mirroring app anyways; Chromecast cannot receive a Screen Mirroring signal from the iPhone. You are also going to experience lag, and should avoid entering passwords or other sensitive information during the presentation. Some videos, embedded widgets, and sites that refresh their content dynamically may not work correctly even if the rest of your browsing page is fine.
If I am giving a long presentation, I will forgo iPhone Mirroring completely if I have the option of using a computer. I’ll open the relevant page in Chrome on the computer and cast it to the TV. Desktop cast is a lot less temperamental than relying on the translated input from a phone touchscreen and works much better with pointer input.
So the long story short is: cast photos, not web pages, unless you need to demonstrate some interactivity. If you do cast web pages make sure it is for a short presentation. Lag and connection issues will happen and you should avoid giving away personal information over a live cast. If you need to regularly mirror your phone screen for something more involved then get a wired video cable or an AirPlay receiver.
Nobody’s flagged that the wired route @turb0_hawk suggests isn’t as clean as it sounds on older iPhones. A Lightning to HDMI adapter needs Apple’s certified one to work reliably, the cheap knockoffs stutter or die, and even then some protected apps still refuse to play. Fine for photos and a browser though.
I would like to ask why Google Home will not put a mirror button on my IPhone. This was confusing since most Chromecast guides are written for Android since it is built into the OS for fullscreen casting, while with iPhone, Google Home acts more as a setup assistant and controller for devices, meaning photos would need a cast-enabled app, and a webpage would need to be cast via some other method.
The cable suggestion is incorrect: you have to connect the iPhone’s HDMI adapter to the TV, not to the Chromecast. By doing this, you completely bypass the Chromecast. It may work for your photos and for the browser page, but it will not show up in the Screen Mirroring menu of your iPhone.
Test the actual browser page before shelling out money for a mirroring app. Being able to find the Chromecast and send a photo is insufficient for your purposes; make sure that the page on the TV reacts to your scrolling and menu-opening as you navigate it, not just displaying video from it.
